Question about HTC Touch P3450 Smartphone
How to copy contact to computer
I want to store the contact to my hardisk
    Scholar:
  • 122 Answers
You can download all contacts, notes, and calendar entries etc with Microsoft active sync in windows XP. With Outlook you can make changes on either the pc or the phone and it will update with options to make the phone or pc priority or ask which is the most up to date. Good Luck
Posted on Jul 23, 2009
In start up my computer says system fail need a boot disk
Windows was corrupted and it must be reinstalled. Use the recovery disk that came with the pc when you bought it.
May 30, 2010 | Compaq Presario 5000 PC Desktop
When i try to start up my laptop, i get a black screen that says "NTLDR" is missing" and "press Ctrl+Alt+Del to restart" when I restart it, the same screen just reappears. I've also tried pressing F11 to...
The file can be copied from different computer using the same operating system and same version..It can only be done if you can hook up your hardisk from that computer and make it as slave...go to search file and search for the NTLDR file and its directory. copy the file and save it to the same directory of your hardisk slave. If file copying is successful, disconnect your hardisk from that computer and connect it to your laptop, then try to boot.
If that did not work, you can repair your missing file by running your windows installer. Make your cd rom as first booting device and run the setup of windows, when prompted, press F8.. follow some instructions. After searching previous windows system press R key to repair the system.. The set up will restart your unit once its complete.
i hope i help you with this...
much appreciated if you rate this solution..thnaks.
May 29, 2010 | Gateway 7330GZ Notebook
Software problem
SMART is the system that monitors the health of a hard disk, in your case  it's close to complete failure. Follow immediately what that warning message says - copy all your data to some DVD's, replace the hd and reinstall.
Oct 31, 2009 | Toshiba Satellite U300-ST3091 Notebook
IR3570 error code E000602-0003, screen won't come on, won't copy or fax
this error is related to machine hardisk problem/failure,,It needs hardisk replacement with IR 3570 sytem software You need to contact your service provider to fix this problem
Jul 19, 2009 | Canon Office Equipment & Supplies
Hardisk
Normally is a IDE hard disc. What u can do is to unplug the copier hdd, and u can differentiate what kind of hdd is using...
Mar 29, 2009 | Canon imageRUNNER 5000 Copier
Widows setup failure..
Greetings
It is not the cd that has a problem, its your hardisk if you have other hardisk try to exchange it and re-install your computer. or format your computer with other comupter.
Thanks
Nov 16, 2008 | ASUS (GENEIRC DRW-1608P BLACK)...
My computer freez and go blank after formatting the computer
Greetings,
There is no problem with your computer as a whole it is your hardisk that has a problem, It cannot continue installing the system files because an error occur in your hardisk. Format your hardisk with other computer.
If you have an extra hardisk much better.
Thanks
Nov 12, 2008 | IBM NetVista PC Desktop
ThinkPad T20 2647....BSOD at startup...before asking for password
If you can attach your hardisk to any Desktop Windows OS computer, you can use the "Check Disk" by windows to check the problem of you laptop hardisk, usually using USB Eclosure will help you connect your Laptop Hardisk to Desktop Computer. Just use "Check Disk" utility to check the Drive, you can do this by clicking MY COMPUTER, then Right Click on your Laptop Drive then PROPERTIES, then TOOLS and click CHECK NOW, then place a check mark on the "AUTOMATICALLY FIX SYSTEM ERRORS" then start fixing, after that, then put back your laptop hardisk on your laptop and see if its works.
-mrsolution
Jun 11, 2008 | IBM ThinkPad T20 2647 Notebook
Hardisk have difrent amount
Because Compaq has a hidden partition on you're C:\
Stored in that hidden partition is Compaq's restore drivers & software. If & when you need to run the restore CD on the Compaq, the restore CD enter's that partition & uses the software to help in the process of restoring the C:\ drive to factory settings. (This is normal for most Compaqs).
Mike
May 07, 2008 | Compaq ProLiant ML370 G3 (340262-001)
Data not copy other hardisk
Maybe your secondary hard drive is write protected due to third party software during the old installation of the system such as norton data recovery.
Hope this will be helpful to you.
Oct 26, 2007 | Apple Drive Module 180 GB ATA-100 Hard...
HTC Touch P3450 Smartphone Logo
Top HTC Computers & Internet Experts
Tom Chichester
Jerry Kramer
Jerry Kramer
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
