Bought a nabi 2 (NABI2-NV7A), Black/Red tablet. Want to download Disney Jr Channel. Cannot because was told the company does not have the rights/contract yet. Wondering if that has been resolved yet?
Remove the rubber case of the Nabi Jr. Then press the Volume + and the Power Button. Calibrate the screen. Wait for the calibration until it is completed. But if it is still frozen, press on the power button for about 10 to 30 seconds to shut it down. Then restart the device.
? 2:11
https://www.youtube.com/watch?v=hpNcm5x2QHc
Feb 21, 2013 - Uploaded by Pam Morris
If you have not updated your nabi 2 to 3.0 Blue Morpho then you can change the ... settings > Apps > Maxthon Kidsafe browser > clear data > Ok > Force stop > ok. ... I'm receiving a invalid password in dad mode how you fix.?.
? 13:23
https://www.youtube.com/watch?v=EhtTgrjcrrk
Sep 26, 2014 - Uploaded by Pam Morris
This video will help you determine why your nabi tablet is not charging. Use it to see if you need a replacement cable, USB wall adapter or if the tablet its... ... What might be wrong and how to fixit! ... Nabi 2: Accessories!
? 1:01
https://www.youtube.com/watch?v=DBlFsC4HNdU
Aug 29, 2015 - Uploaded by Android Mods & Hacks
This video will show you how to fix " Unfortunately Google Search has ... 2:47. Android Error - Unfortunately (app name) has stopped- Fix - Duration: 9:35. ... Fix "Unauthorised Actions have been detected" Error by Disabling ...
If using the supplied / original BLACK and WHITE USB cord, the black must be used for charging. The white is for data transfer only and lacks connections for power / charging.
Most USB chargers will output 1 amp or less. Many USB jacks on computers output between .5 and 1 amp - max. Your device calls for a charger with 2 amps output. Connecting to devices such as those mentioned above can overload and damage the charger or computer - don't use them!
USB ports have standard connections or "pinouts". You should obtain a USB charger (5V DC) rated for 2 amps (or more for better performance). Be sure to select one with matching USB connector (compatible with your device) - mini, micro, etc.
Sounds like you have a good charger/cable, so try resetting the Nabi that's giving you trouble. Hold the power switch down for 10-20 seconds to reset the unit.
I have a couple of NABI-2 tablets and they both react differently to the charging cables; I often have to shut the NABI off completely to charge them. Also, getting the charging cable to connect can be challenging - I will plug the cable in and out several times waiting 10 seconds or so to see if the green LED will go red.
I have contacted my warranty company to see if they'll fix mine: the kids have cracked the screen. Fine crack all the way around but the Nabi still works. Will see what they tell me about how they fix it. Have seen ads for the LED and another part that comprise the screen. Not sure which is the right one. One runs about $40 the other $15. (Craigslist is another alternative.)
