The main power button to the TV was taking its time to show a picture when powered on. When switched on today the picture came on then a sizzles sound happened and now no picture. there was a burning smell when it happened. What could thid be and is it fixable.
  • 1 more comment
  • andyfryer Jul 23, 2009
    Model LG RT-44NZ23RB
    Can I fix the problem or is it best getting a repairman in to fix and is it an expensive fix.
    Thank you mate you,ve been most helpful, I just hope its not major.
  • 8,617 Answers
Possible flyback problem. Whats the model nuber of your set?
Posted on Jul 23, 2009
  • Sonny Berry
    Sonny Berry Jul 23, 2009
    Its most likely the flyback or one of the HV cables has shorted out against the yoke. Both are fairly common problems with that model number
  • Sonny Berry
    The parts are a little hard to find, so it may be best for a repair tech if they are famillar with LG/Zeniths
Sony Cyber-shot DSC-H5 Digital Camera power button does not work
In today's cameras on off button only give a pulse to processor to switch on.actually camera is on all time technically.only screen is off.Your problem may be flex connection to main board has failed. The group connector for on off, click, Tele, wide, all together forms one connector. Whole part to be replaced by camera technician to save your camera.
Sep 30, 2017 | Sony Cyber-shot DSC-H5 Digital Camera
TV won't show picture the power and OPC light blink twice together followed by three blinks from the OPC alone.
The main tv Tuner signal board have problems or it is dying or might be dead already.But sometimes this tv will still work and can be used,i have the same tv have the same problems it work for me all the times.By doing this process.Everytimes Power and OPC lights blinks.Just push the remote power switch again for tv to repower the tv power and OPC lights again,have go thought this process pushing power remote switch again have to do this like 3 or 4 times sometimes before the tv to work.Tries websites like Shopjimmy.com or Ebay.com to buy a whole new refurbish main tv Tuner signal board for the replacement.
Jul 30, 2011 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp lc-c5277un, tv turns on but no picture, switched the cable to the blue ray input and worked but no other inputs work. Happened before, Costco had me do some kind of reset and worked till today.
your main board that takes all the input is the cause to this problem. you can try to reset the tv by disconecting it from the power outlet, then press the power button on tv (not on the remote) and hold it down for 30 seconds
Aug 24, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Power light comes on but no picture at all...
There are several more fuses in the TV, but they are not like the main power fuse. Most of of the time there black with and lead coming out of each end about the size of a resistor. I think there are 9 of them, you will need an ohm meter to check them and a soldering iron to replace them. Good luck Eric.
Jun 01, 2010 | Toshiba 57H82 57" Rear Projection...
What is wrong with my Panasonic PT-L711XU projector?
try to clean the air filter of your projector... in case the problem occur check the lamp ballast board and replace it.
jahting
Oct 10, 2009 | Panasonic PT L711XU Multimedia Projector
Picture does not show and power goes off.
There is a capacitor that started out with a bad solder conection and is now burning the board. This capacitor should be replaced.
Jul 07, 2009 | RCA P56923BL 56" Rear Projection...
Exactly same problem just happened today! Only power button on the TV set and remote control works, no sound
I had this problem happen to me today. What i did was unplug the tv for an hour and when i plugged it back in, the first time setup appeared on the tv. The remote and the tv buttons worked fine after that. Hopefully that works for you too.
Jun 06, 2009 | Panasonic PT-52LCX66 Projection Television
Tv does not come on you can here it sizzle when you push the power button but no sound are picture its a mitsubishi vs-5003r prohection tv
a "sizzle" sound is not ggod especially if you can "Smell" it, I say call a service tech to give an estimate, if you are not electically inclined
Apr 20, 2009 | Televison & Video
TV on, sizzling sound, smell smoke, picture goes out but TV still on
It could be any number of components on the main board/power board which could be frying..But if you are hearing a sizzling sound, it could be something probably like a capacitor or the board itself. Difficult to say unless it is opened. First thing, though, is unplug the TV from the mains as a precaution against fire.
Since you are a technical guy, it shouldn't take you long to figure out what the components are thats burning. However, if your TV is under warranty, I advise against opening up the set as that will void your warranty. However, if its not under warranty, go ahead and open up the set and see what components need replacement, or replace the whole power board itself (if you are comfortable with electronic soldering/desoldering).
Cheers!
IrishDruid
May 10, 2008 | Protron PLTV3250 32 in. LCD Television
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
