Question about GE Profile Harmony DPGT750GC Gas Dryer
GE gas dryer model DVL223GB6WW with no heat but drum spins
This dryer spins when started. I can hear the glow igniter click on and glow and then eventually I hear it click off.
jsrock516
  • 5911 Answers
SOURCE: After a few heating cycles the burner does not ignite
The problem you are describing is usually associated with a bad gas valve coil. The dryer runs normally until it gets hot, then starts making a strange clicking noise. After it cools down, the dryer runs normally again. The gas valve coils (there are two of them) usually run about $20 a piece. I recommend replacing both of them at the same time just to be sure. I hope this helps.
Posted on Apr 29, 2007
jsrock516
  • 5911 Answers
SOURCE: no heat
You may have a weak igniter. Just because the igniter glows, does not mean it is working properly. The glow bar type igniters are supposed to draw a certain amount of current in order for the gas valve to open. If the current potential is never met, the gas valve will not open. This is a safety feature used to prevent gas flow without ignition. The current readings for the igniters are as follows: Round style glow bar: 2.7 to 3.2 amps Square style glow bar: 3.2 to 3.7 amps If it is reading less than the required amperage, replace it. This may just solve your problem. Let me know if this helps you.
Posted on Sep 08, 2007
  • 848 Answers
SOURCE: amana gas dryer
check the thermal fuse ........
Posted on Aug 28, 2008
docjohn174
  • 943 Answers
SOURCE: Maytag Neptune MDG300aww Gas Dryer Heats On and Off
hI YES THE COILS IS WHAT YOU HAVE TO CHANGE thANKS FOR THE QUESTION tHE APPLIANCS DOC
Posted on Sep 12, 2008
docjohn174
  • 943 Answers
SOURCE: Dryer does not ignite (Gas) - no heat?
HI thanks for your question. no clicking sound when you turn it on. check the thermal fuse at the back on the air duct. a small plastic piece of plastic with 2 blue wires to it. replace this part. thanks the appliance doc. please rate my answer. thanks
Posted on Oct 09, 2008
Drum rotates no heat,igniter dosent start
While the drum is rotating you should hear the CLICK associated with the gas valve assembly powering up to give out a blast of heat. If ya don't hear no click check the duct fuse. Right next to the control thermostat. If it is blown it kills the circuit to the gas valve assembly. If that fuse is good and the control is also good, then check the flame sensor for continuity, If it is open then the ignitor won't glow. The ignitor must glow and change in resistance then the flame sensor must open up and kill power to the ignitor so that power will be shifted to them coils on the gas valve.
Sep 03, 2011 | Maytag MDG2706A Gas Dryer
GE Profile gas dryer, DPXB515, no heat and no drum spin
the humimg you hear is from the motor,check the blower wheel that is below the lint filter,if a sock or something gets sucked into the blower the motor can't spin,check the belt,if it is jamed the motor can't spin,if these things check good you have a bad motor
Nov 05, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
My ge he gas dryer is not igniting
your dryer may have a spark igniter or a hot wire igniter .. those go bad after so many hours .. if you look in where the flame usually is .. as your start the dryer, you should see a small glowing wire if its a hot wire igniter .. or you should hear clicking and see sparks if its a spark igniter .. if you dont see/hear either then thats likely your problem .... both of those parts are available from washer/dryer parts distributors or GE parts on the internet .. but you have to know the make and model number of your dryer .. you should find that on a tag inside the door or on the back. .. if it actually ignites but quickly shuts off then you probably have a clogged exhaust hose or lint filter chamber .. it reqires a large unrestricted air flow thru the machine. if that is blocked then a sensor shuts off the gas in just a few seconds . . i am assuming that the drum is turning .. if not then thats a whole different problem ..
Oct 07, 2009 | Dryers
GE Gas Dryer (Model DQSR 483) Drum works but does not heat
There are three things besides what you aleady checked:
1. Open the small access door in front of the dryer and start the heat cycle. The ignitor must glow a bright orange so that it is hot enough to light the gas. If there is no orange glow, then the ignior needs replacement.
2. If it glows then cuts off, then glows, again and cuts off, the thermocouple sensor wire is out of position. It needs to be very, very close to the ignitor. This thermocouple sends a temperature signal when it senses that the ignitor is hot enough to ignite the gas. Unplug the dryer. Re-position the thermocouple wire mount so that the thermocouple wire is almost touching the ignitor. You may also "bend" the wire. Plug power back on and heat.
3. If it still does not heat, then the automatic gas valve that is controlled by the thermocouple sending unit is broken. The automatic gas valve cannot be safely "fixed" and must be replaced.
Hope it's just the thermocouple wire.
Oct 01, 2009 | GE DBXR463EBWW Electric Dryer
My GE Dryer, model number Model# DSXH43GV1WW doesn't heat up anymore. The dryer turns on, the drum spins, in all the three types of available cycles, just no heat at all. Any ideas?
First make sure that the gas valve is on. Then verify that the gas connector is not kinked or restricted. then remove the connector at the back of the dryer and make sure there is gas pressure. Then visually inspect the pipe at the back of the dryer. Use a flashlight to inspect inside the pipe and make sure there is no debris inside the pipe that could restrict gas flow. On this dryer there is no removable burner door cover on the front or inspection window so you will need to remove the back panel of the dryer. Once the panel is removed you can turn on the dryer. You should first hear a click sound. That is the first gas solenoid valve opening. Then the igniter should start to glow. Once the igniter reaches 2200 degrees the secondary gas solenoid valve should click and the burner will come on. If you do not hear a click when the dryer is first turned on you will need test the first gas solenoid valve. Make sure it is getting voltage with a fluke meter. You can also touch a piece of metal to the top of the valve and the top should be magnetized when active. If you hear the first click but no igniter glow then verify the igniter is getting voltage and test the igniter with a fluke meter. You will need to test the ohms and most should be 500 to 700 ohms. If the igniter does not get a good reading or none it is probably defective and needs replacement. Usually most places that sell appliance parts will test the igniter for free. Just because the igniter glows does not mean that it is good. It can glow but not reach the 2200 degrees needed for the proper operation. Now if the igniter is good and you hear a second click then there might be a restriction somewhere in the gas line between the solenoids or the gas orfice at the burner. The sensor Gort was talking about is the flame rectification sensor and can detect the flame. It is rare for this to be faulty but not impossible. If you get flame for a couple seconds and then it shuts off it could be this sensor. Blow the burner assembly and this area off with compressed air and lint can block the sensor's ability to detect the burner flame. Also I believe your dryer has a larger fan blower than standard dryers. If this blower motor is not working the rest of the system will not come on. make sure the assist fan is working and that the vacuum switch is working and not stuck. Also check the vacuum line is not disconnected or restricted. And always remember that there are exposed power connections inside the dryer that could shock you and cause injury. use caution and if you do not feel comfortable working on this you might want to call a professional.
Sep 25, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
Gas dryer Amana Model LGA30AW, rattling noise, no heat.
I was experiencing a similar problem. I just repaired mine yesterday, with the help of this web site. Remove the front bottom panel. The are two screws located on the bottom of the panel. They are there, just slightly hidden. Turn on dryer to heat. Look inside where the panel was. Wait a minute or two and you will see the igniter glow. After a minute or so you might hear a click and the gas valve will open to start flame. After a while flame will go out until it cycles again. If your igniter glows and you hear the rattling noise and then the igniter glow goes out and you have no flame, it might be your solenoid coils are bad. These are the two black round things located on top of the gas valve. Make sure your gas dryer is unplugged. There is a wire clip attached to each solenoid. Unplug them. I needed to pry them off carefully with a flat screwdriver. There is a metal bracket holding those two solenoids in. There are two screws that you will need to remove the bracket. Use a flashlight to see them. Slide them up and off the gas valve. One is a 2 prong and one is a 3 prong. I bought a new set for 26.75. Put the new ones back the same way as you took them off. The is little nips on the top of the solenoid that line back up with the holes of the top bracket when reassembling them. Plug your machine back in and turn on and watch to see if the ignitor glows again and watch for the flame. Put panel back on and enjoy dry hot clothes again. GOOD LUCK
Aug 09, 2009 | Amana ALG331RAW Gas Dryer
Dryer does not release any heat
Is yours the gas model? If so I need you to look for some things. Open back door panel and see if while trying to light the igniter is glowing orange. Sea Breeze
May 22, 2009 | Whirlpool LGB6300 Gas Dryer
Apr 15, 2007 | Maytag MDG3600BW Gas Dryer
Dryer spins but does not heat
It sounds like to have a bad igniter. In order for your dryer's gas valve to open,the igniter has to be functioning properly. This is a built in safety feature to prevent gas from flowing without ignition. The igniter is located inside the machine usually under the drum near the gas valve. If you can access the inside look for a glow after you push the start button. If there's no glow, your igniter is bad. I hope this helps.
Mar 30, 2007 | Frigidaire FullFGX831C Size Stack Gas...
GE Profile Harmony DPGT750GC Gas Dryer Logo
151 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
