Question about RIM BlackBerry Pearl 8100
The address on my pearl just disappeared
My address book disappeared and only shows "business" contacts -- i don't have any.
the numbers that were on my SIM card are still there but all the numbers i have added (and deleted) since i got my phone are erased!
what should i do?
i tried removing the battery and restarting but it didn't fix it
  • 541 Answers
Click on main menu,select address book,click menu,select filter,if there is a check mark on business cancel it and now you will get all your contacts.
Posted on Jul 23, 2009
How to put phone numbers on the blackberry 8120
you have 2 options. you can load them directly in your "address book" by going into your address book, menu button (bb icon left of trackball), select "New Address" and enter the info.
Option 2 , would be going into your address book, select "SIM phone book" and enter the info there.
Keep in mind, when you use the SIM phone book option, you can only enter their name and phone number, and after you are done, you have to import your SIM contacts to your address book.
Any contacts saved using the SIM option, will stay on your SIM card.
Any contacts using the Address Book option, will only remain on the phone, and not on your sim card.
ho[pe this helps!
Oct 30, 2009 | RIM BlackBerry? Pearl 8120 Cellular Phone
My address book is hidden...when i click on the address book icon it says "no addresses found" how do i get it to show my address book so that i can edit my contacts?
go to the phone book settings then change the memory in use. for eg. from phone memory to sim memory (or) from sim memory to phone memory...........
Sep 28, 2009 | RIM BlackBerry Pearl 8100
Update contacts new phone number in blackberry pearl 8230 Also, how to access call history and make the back light brighter
Update w/ new number: Go to Address Book, begin typing name, scroll to contact and select, with contact showing press the Blackberry button and choose "Edit".
Backlighting adjustment: Options>>Screen/Keyboard>> adjust the brightness setting (listed in % 10-100). Then press the back button and Save your settings when prompted
Short call history available by pressing the green phone key.
Aug 01, 2009 | RIM BlackBerry Pearl 8130 Cellular Phone
When i pull up my address book, it show "Business" contacts...I am unable to change it to "Personal" address book. Any suggestions?
To change it to personal contacts follow the bellow mentioned steps:
1) Select adress book
2) Press menu
3) Select filter
4) Check on personal
5) and you can enter ur contacts under personal contacts.
Jun 22, 2009 | RIM BlackBerry Pearl Smartphone
Address book
open your 'empty' address book and click on the MENU button (left of the rotater wheel) and select FILTER and UNCHECK anything that is checked there. All your addresses should reappear. It happened to me and I have no idea how it happened, but it was a relief to get them all back so easily. Hope that works.
May 28, 2009 | RIM BlackBerry Pearl 8100
How do i find numbers that are saved to my sim?????
Most phone have settings to display, only sim contacts or only phone contacts or both
the user manual explains it and it is available in the following link
http://downloadcenter.samsung.com/content/UM/200810/20081030012522500/att_a867_eternity_ug.pdf
Address Book Settings
1. Touch ➔ Address Book Address Book Settings.
2. Touch any of the following options to activate a function:
• My Business Card: attaches a user created virtual business card
as an attachment to outgoing messages.
• Save New Contacts to: defines the destination for new contact
entries (Phone or SIM Card) (page 95).
• View Contacts from: to filter the display of current Address Book
entries. Options include: All, Phone, or SIM Card (page 91).
• Own Number: to display your current phone number (page 93).
• Fixed Dial Contacts: assigns phone numbers as FDN entries
(page 93).
• Used Space: displays the memory storage allocation (total available
and remaining) within both your Phone, SIM card, and FDN list
(page 97).
Hope this helps !!!
Apr 18, 2009 | Samsung Eternity Cell Phone
My address book always shows up empty, but the numbers are stored somwhere on the phone because the caller ID shows up with name, number, pic, everything. even if i save a number in the address book, it...
Are you sure another address book isn't hidden? You can view all apps to see if it shows up. If you click the menu button and show all or unhide. If that doesn't work try switching to another theme.
Mar 31, 2009 | RIM BlackBerry Pearl 8100
My Address book for my BB pearl 8100 just disappeared
Seeing as this is a blackberry I need you to do a hard reset- take the battery out of your phone while it is still turned on, then let it reset itself. If that doesn't work, consult with your phone company's tech support. Good luck
Mar 19, 2009 | RIM BlackBerry Pearl 8100
Can't view my contacts in the address book
You have a filter on. When you see the screen that says "no addresses" you need to go to the top where it says "FIND:" then click the "Blackberry" key to the left of your trackball. Scroll up to "Filter" and click. One of your "categories" is checked. Click on whatever one is highlighted to uncheck. All of your addresses should pop up.
Feb 28, 2009 | RIM BlackBerry Pearl 8120 Cellular Phone
Address book
That's easy just goto your address book
2.press the menu button
3.select filter
4.press the menu button again
5.and select uncheck filter'
thats should make your contacts reapear
Jan 22, 2008 | RIM BlackBerry Pearl 8100
RIM BlackBerry  Pearl  8100 Logo
244 people viewed this question
Top RIM Computers & Internet Experts
ismael castillo
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
