SOURCE: steering has let go on my craftsman 17.5 lawn tractor
take it in it should be fixxed & ask them if its covered under warrenty
SOURCE: How do I fix a broken steele line on a John Deere
Your old line most likely broke off at the end of pipe due to vibration,your new one will come as a kit with a clamp to prevent it happening again.To replace it all lines must be removed from steering pump along with driveshaft and carefully put the new one in.At the dealer it takes about 1 hour depending on the tech to know what hes doing.
SOURCE: my steering on my lawn tractor is not working, i
There is a brass or bronze pinion gear at the bottom end of the steering wheel rod, take it off and turn it around (upside down) to make the unworn parts of the pinion engage the rooster gear or replace both of the gears for tight steering again.
SOURCE: Poulan Lawn Tractor 42" 14.5 hp Model 733-864 How ...
I need the diagram for a drive belt for a 42'' lawn tractor - 14.5 hp Can ANY ONE help me?
SOURCE: Craftsman Lawn Tractor-steering problem. Manually
What is the model number of your tractor?
Richard
Roth
The
FixYa Team
