I have tried looking on line and the curren Braun Company has no info as they are not made anymore that I can see. This one was built in the USA
SOURCE: instruction manual for LG microwave convection oven
You
can download Samsung over the range microwave installation instructions
here. If that's no good, try here.
Otherwise, visit this page, click on click on the left-side arrow "Busque por Codigo del Modelo" in the big purple rectangle, enter your model number in the box, then click "Buscar". They may list an English version manual available for download.
Good luck.
We're happy to help you and we'd appreciate your
thoughtful rating of our answer.
SOURCE: Looking for instruction manual Sharp \carousel
if you google the model number and the brand you should be listed with a series of sites that supply manuals, service manuals, etc.
SOURCE: manual for sharp grill 2 convection oven
where is the fuse at on the sharp grill 2 convection
SOURCE: Built-in Sharp Carousel II Microwave Convection Oven died.
There are a couple of safety thermostats in the oven to shut down power if something overheats. One is on the magnetron tube (the microwave source), the other is on the cooking cavity. These sometimes go bad. There's also a power line fuse that may have failed, or become loose in its mounting clips. These can be tested with an ohmmeter; they should all measure very close to zero ohms if they're good.
Another possibility is that the control circuit board in the oven may have failed. I have worked on several Sharp ovens where the power transformer for the board has gone bad for no good reason. If the board goes bad the oven may appear to be dead as well.
Microwave servicing is best left to professionals. If you're thinking of keeping this one, take it to a service shop (or call for home service) and get an estimate. Then decide whether to repair or replace.
Hope this has helped a little. Thanks for using Fixya!
Testimonial: "Thank you. I will check it out and then decide whether to repair or replace."
SOURCE: Looking for a printable/downloadable owners manual
Go to managemylife.com and type in the model number you provided under the "Manuals" link. Your owner's manual is available in a .pdf (Adobe) format that you can download or print for FREE. I hope this helps you.
Most major manufacturers supply manuals
online so if you were to log on to the manufacturer's web site, you
may be pleasantly surprised as usually, if available, one is able to
download, by model number, Customer
Instruction Manuals, Dealer
Network for spare part supplies and
Driver
downloads
(if applicable)
as required.
The information is normally free of
charge.
I hope this helps.
If you were to log on to the
manufacturer's web site, I think you will be pleasantly surprised as
usually one is able to download if available, by model number,
Customer Instruction Manuals,
list of Dealers,
for spare parts and service,
and
Installation Instructions
as required.
I hope this helps.
usually one is able to download, by model number, Customer
Instruction Manuals, list
of Dealers,
and
as required.
I hope this helps.
of Dealers for spare part supplies and
Driver
downloads
(if applicable)
as required.
charge.
I hope this helps.
of Dealers for spare part supplies as required.
charge.
I hope this helps.
