Our church has a Sharp Copier with an H4 error we do not have a manual and I do not know how to fix the error, can anyone help me?
    Master:
    Sergeant:
  • 226 Answers
It is the fuser, but sometimes it is just a false code. to reset enter buttons clr, exposure, clr, exposure, the display will blank, enter 14, press prnt button, then clr several times to get out and thats it.
good luck.
Posted on Jul 23, 2009
How to fix Sharp Copier AR-5731 Error code
good day, my Sharp AR 5731 showing the message Call for Service . Code : H4-00 can you help me to fixed my problem. thanks and God Bless
Mar 11, 2013 | Sharp AR-BC260 Color Copier
Sharp AR-235 shows error H4-00, would like to know how to fix without costing me.
Noy likely you can fix this without replacing the fuser lamp H4 means the fuser lamp is not getting to temp. It cold be a fuse on the fuser unit,too. Checking with an ohm meter is only way to know which,
Feb 07, 2011 | Sharp AR-235 Copier
Sharp ar 5516 printers error h5. h4
hi,I have error code L h on my coppier sharp 5516. your help please.
Aug 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
Display panel h4 code any clues?
This error is displayed when the Fixing heater has not reached normal operating temperature after a specified time.
It is usually a blown heater element.
You will need a technician to repair this.
May 01, 2010 | Sharp AR-235 Copier
I have a sharp copier, model AR-285, H4-01
H4 error pertains to lamp errors.
that would either be the copy lamp or the heater lamp.
check both lamps.
with heater lamps,it's usually caused by either a broken heater lamp or a dirty thermostat on the heater roller assembly.
Jun 09, 2009 | Sharp Office Equipment & Supplies
System error H4-00
H4 indicates a heating problem in the fuser. The roller never reached a specific temp. Make sure the fuser is free of any left over paper pieces (maybe from a paper jam). Check to make sure its clean.
Try reseting the the error in service mode.
To enter the test command mode, press the keys as
follows one after the other :
[#] key [*] key [C] key [*] key then enter 14 and press start/copy key. this clear error counter. make sure to restart copier afterwards.
May 19, 2009 | Sharp AR-168S Copier
SHARP AL-1216: HOW TO REMOVE H4 ERROR CODE
www.tinli.com.hk/PDF/AL1216.pdf
Hope this helps.
paul
Nov 01, 2008 | Office Equipment & Supplies
HELP, H4 ERROR
The fuser isn't heating up on time. You could try turning the copier off for 30 seconds and turing it back on again to see if it goes away.
If it doesn't happen, there is a part that has to be fixed on the fuser to correct the problem. Usually it is the thermistor.
Aug 16, 2008 | Sharp AL 1215 Black and White Copier
SHARP AR C250 Digital Color COPIER HAS SERVICE CODE H4 00
Press P-interrupt-C-interrupt and enter test command 14 and Execute to clear your error. Let your machine reboot. If it comes back you have a problem with your fuser. Most likely it's dirt or toner caked on your tempature sensors and they need to be scraped off.
Mar 17, 2008 | Sharp AR C250A Color Copier
H4-00 Error Code for Sharp AR-168D
Your Tech is correct in replacing the Unit.
If the Fuser is not reaching the correct Temp it will give the H4-00 Code
The time and money it takes to repair the unit is greater than replacing.
Oredering all the parts for the unit takes longer then ordering the unit.
The only thing a tech can do is clean the Thermistor, reset with sim 14..
If that works, it might work for a hour, might work for days?
I personally carry this Fuser Unit in my car stock as this happens frequently..
Good luck
Oct 22, 2007 | Sharp AR-235 Copier
99 people viewed this question
jasbo
jasbo
