Canon Pixma MX 310 print smears.
My Canon Pixma MX 310 prints and copies with smears eveuy seven lines or so. I went through all the suggested remedies in the troubleshooting guide, (exept reloding the drivers, which I donto think could be the cause of smearing. Then I went to try cleaning off th rotrusions. I see looks like ink on the foam that is below and in front of the protrusions. Might this be causing the smears? If yes, what should I use to try to clean the the ink off the foam? Any other suggestions?
    President:
  • 2,306 Answers
You need to clean the bottom of the printhead, and use a Q-tip to clean the wipers on the clean station that is on the right side where the printhead parks. There are 2 or 3 squeegees there that wipe the bottom of the printhead and when there's too much ink it stays on the printhead causing the smears.
Posted on Jul 23, 2009
Canon mx 850 problem is when the copy button is pushed to make a black and white copy the printer acts as if it is printng color. Prints very slowly. Phil
I do not know the Canon MX 850 but it seems like your printer is set to default to high quality printing. Check the setting in your Canon software for something like this.
Aug 23, 2011 | Canon PIXMA MX850 Multifunction Printer
Canon MX-310 printer: How to remove double-sided printing option?
Duplex printing is set in the print dialgue box. You may have set a profile where duplex printing is automatic and the computer is defaulting to that setting. Make sure it says "Standard" in the print dialogue box.
May 02, 2011 | Canon PIXMA MX310 All-In-One Printer
I have a Canon MX-310 Printer. Excellent. But, how can I print pages double-sided?
Hi!
Unfortunately it does not have a duplex function and you will have to manually duplex the pages meaning,Print and turn the page around and print on the other side!
Sorry!
Apr 02, 2011 | Canon PIXMA MX310 All-In-One Printer
CANON MX 310 NO COLOR CARTRIDGE CAN i PRINT IN BLACK & WHITE
Hi there
No you will not be able to print just with back ink alone, the printer will not work it needs all the inks, sorry.
Take care all the best Pineworks
Mar 14, 2010 | Canon PIXMA MX310 All-In-One Printer
I have an MX 310 that recently started to only print the top half of any page i want to print. Any ideas on what to do? I use it with a MAC
Make sure that your page is set for the correct size in the application you are using to generate the print file.
Don
Feb 14, 2010 | Canon PIXMA MX310 All-In-One Printer
MX-310 has fax's in memeory but keeps printing the first page of the first fax only. Screen says check paper size. When i push ok it only will print the first page over and over. How do I change it?
If your Canon MX-310 has been set up to print faxes as they are received, then what is actually in memory is a "received fax report". If you select a particular fax in this report, it will print the first page of the fax to remind you of the content.
Your Canon MX-310 will store fax documents in memory if:
  • Ink is low or has run out
  • The paper size and type is not set correctly
  • Paper has run out
  • The Output Tray is closed
Dec 04, 2009 | Canon PIXMA MX310 All-In-One Printer
Black and white printing on Canon MX 310
there is in adjusting the seal the printer bookmark, seal grayscal stile. Search for in adjustment before printing
Apr 24, 2009 | Office Equipment & Supplies
Sending a fax directly from computer using Canon Pixma MX 310
With the document open, you click Print, then choose Cannon ...Fax.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15603
Jan 02, 2009 | Canon PIXMA MX310 All-In-One Printer
MX 310 Not seen in Mac printer list, so cannot install
Had a new hard drive installed and need to re-install Canon Pixma Mx 310 all in one back in my Mac
Dec 16, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon MX 310
my suggestion is try to reinstall your printers driver after you reinstall the driver diagnose the printer and try calibrate
Mar 21, 2008 | Office Equipment & Supplies
379 people viewed this question
jasbo
jasbo
