Question about Magic Chef CAV2000 Top Load Washer
My washer wobbles badly during the spin cycle even when empty...?
I pulled the lid and pulled the panel off the bottom in the back and looked around on the inside but nothing seems to be loose or broken.
Any suggestions?
    Problem Solver:
  • 19 Answers
Sho`ker bolts may loose
Posted on Jul 23, 2009
What are some reasons why my GE stacked washer stops after spin cycle?
Katary, first it sounds like it is a bad drain pump. to access drain pump you need to remove the front panel, to remove the front panel there are 2 screws at the very bottom of the front panel near each corner. Once removed the bottom pulls out and the panel will lift up 90 degrees before being able to be removed from the top "hinge" point. Once removed you will see 2 large rubber hoses, 1 short and 1 long, in between the two is your electric drain pump. It should be on and "humming" during the spin cycle. appliancepartspros.com have that pump for $106.00
May 14, 2014 | GE WSM2780W Stacked Washer / Dryer
I tried washing a rug - I believe it was too heavy and moved the washer around during the spin cycle. Now it is not spinning, it make the sound but it won't turn - I can move the tub around with my hand...
Hello- First unplug the washer. The out-of-balance switch may have gotten tripped. If you open the lid and look in the space between the tub and the top in the rear right corner you should see a plastic "arm" sticking down, reach you hand back there and move it back away from the tub. This lever actuates a switch in the control panel that will prevent it from spinning if there is pressure on it, it should be hanging freely away from the tub. Plug the machine back in and test it. If it doesn't work another thing that may be happening is the tub is not engaging on the transmission. With the tub empty reach inside the top perimeter of the tub and lift it up and let it down a few times, sometimes this will reset it and get it to spin. Lastly, i would check that the lid is locking when you put it into spin, the lid lock light should come on and you should not be able to lift the lid. If the lid is not locking you may need to have a F/P Tech out to replace the lid lock. You can test the spin by setting the machine to Permanent Press and advancing the cycle to spin. It will take a few minutes to start spinning usually. Let me know what you discover, good luck. Best regards.
Sep 29, 2010 | Fisher and Paykel GWL11 Top Load Washer
January 31, 2010 Kenmore top loading series 80 leaking from bottom toward front. It started during a wash cycle. I put two wet towels back into the empty washer and put on spin, leaking reoccurred. ...
is the pump leaking?or you could have bad tub seals,follow the center trany shaft up to the tub and see if it leaks there,is it noisy when spinning,you gotta just get in there with a light and look around to see where the water is coming from,if you sent pictures they didn't show up,remove the front cover,take out the two screws that hold the console down,remove the two clips with a screw driver and unplug the lid switch wires and pull the cover back and remove it
Jan 31, 2010 | Washing Machines
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Maytag Performa Washer spins out of balance
There was a recall on the washer base, which caused the unbalanced problem. Find Technical Buletin TDL-0050B-B issued by Matag.
Jul 05, 2009 | Maytag Performa PAV2200
Washer stays out of balance
most likely a spring has come off the tub base. there are three short horizontal springs that surround the tub connecting it to the tripod base and one long spring in the very back that connects the base to the bottom back. check these out and reattach if off.
May 24, 2009 | Whirlpool LSR5132PQ Top Load Washer
Empty washer tub wobbles during spining, plus burning smell
BOTTOM OF TRIANGULAR PLATE ARE 3 SKID PADS, USUALLY WHITE OR BROKEN HALF MOON SHAPE WHEN WORN OUT RESULTS IN THIS
Nov 30, 2008 | Kenmore 24032\24036 Top Load Washer
Excessive wobble
If there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Sep 06, 2008 | Maytag Neptune Washer
Kenmore 70 Series Washer
You probably have a bad lid switch.
May 21, 2007 | Kenmore 15864/15862 Top Load Washer
Agitator Not Working
check your motor coupler, lid switch
Nov 08, 2006 | Hotpoint VBXR1090D Top Load Washer
Magic Chef CAV2000 Top Load Washer Logo
202 people viewed this question
Top Magic Chef Washing Machines Experts
Ian Jones
Dan Webster
Dan Webster
Are you a Magic Chef Washing Machine Expert? Answer questions, earn points and help others
