What is the model number of the printer? What version of Windows are you running? How do you have the printer attached? You may need to install the printer then unplug and replug it in via USB if that's the connection you're using.
Please respond back with this info and I can definitely help you.
Thanks
Tim
Ah, ok great, thanks for the quick info. You will want to go download this file, and in the meantime disconnect your printer
ftp://ftp.hp.com/pub/softlib/software10/COL20946/bi-54970-4/ljP1000P1500-OSX-fulsol-v1.0.6.dmg
If you can't click on it just copy and paste it into your browser. The software on the cd has a known compatibility issue with Mac OS X 10.5+
Once you have this installed go ahead and connect the printer (unless the installation of the file tells you to do otherwise).
Thanks let me know
T
5 Hours?! Wow it shouldnt take that long. Are you on a dialup connection?
I bet it will speed up here shortly
T
Oh, you're in Australia, no wonder. Let me see if I can find a closer one, keep with that for now.
T
Ok give me just a moment here
Strange, it only took me 24 seconds to download the whole file. Get it here instead:
http://micromatikal.dlinkddns.com:8000/c...
Definitely try that, its from another US server but hopefully its quicker, let me know
T
I guess thats just the fastest your connection will go down there to Australlia. This will definitely clear up the problem so I guess just let it keep going. I am monitoring the connection over here and it's fine, so if it errors out again its something on your end.
Keep going at it
It shows you rated my help as negative so I stopped commenting.
Hey there, did you ever get this sorted out? Not sure what's happening with it. Please let me know if you still need help.
Thanks
Tim
Was this the website through which you downloaded the drivers.
http://driverscollection.com/?file_cid=399489231573f9b4ad62f5159c3
I didn't gave you any solutions because you already have taken a lot of pain in downloading the driver. Let tim only proceed with your solution.
For that you yourself will have to approach [email protected] or [email protected] because this is out of my jurisdiction area.
Mahendra
OK, Kindly let me know the web address from where you downloaded your driver and furthermore, what is the latest error you are getting while printing if getting anything. Have you tried taking self test printout from your printer directly.
HP 1008 Laser jet printer
HP 1505 Laser jet printer
HP 2035 high resolution printer
good luck
model no is p1005 i'm using the USB cable that connects the computer to the printer also the mac 10.5.6
Thanks its downloading at the moment and it says its got 5 hours remaining so i'll email you later in regards to if i have any issues.
thanks again
no not dial up adsl (i'm in australia) now it says 15 hours to go? can i do anything to speed it up?
it stopped downloading with an error.
sorry to be a pain but it says its already got 3 hours remaining?
all downloaded and installed i connected the cables and tried to print something and nothing printed?
no it wasn't. the one that tim gave me went for 24 hours so i went to the hp website in australia and downloaded it from them and its all installed it was exactly the same as the one tim gave me to download. now its just not printing anything
okay thanks can you forward this to tim as he hasn't answered my message since yesterday arvo?
i didn't rate anything i got a message from someone else so i started to explain to them then they said i'll have to go back to you so i didn't here from you, someone from fixya commented on ur job it wasn't me, i still need help.....
http://micromatikal.dlinkddns.com:8000/c... i used this one ALL DOWNLOADED FINE, it seems my computer isn't communicating with the printer i print things but it never prints.
