Question about Toshiba CF27H50 TV
No picture I have a 10 year old toshiba tv that has always worked great then one day I turned it on and it had a line through the middle. the sound is fine just no display. If you switch between video modes the line will sorta flash so I know it is working but something has given out any ideas on how i can fix it
  • 23 Answers
Just an idea the t.v. is 10 years old ok. Now look at the back can you see inside if so chances are there is a build up of dust which makes a great t.v. wrecker. So vacuum the dust out and see if that helps.
Posted on Jul 23, 2009
Toshiba 32A42/32A42A. Just moved tv to bedroom, worked great for 2 days, now the picture has vertical lines. Turned it off for 15 minutes, picture came on, 10 minutes later lines appear again. Anyway to...
It sounds that there is any loose solder terminals at the main board, especially with the vertical scan output section circuit. It will be best to contact any service technician to get it repaired. Gopakumar Gopalan Google
Mar 09, 2014 | Toshiba 32A42 32" TV
I got multiple thin colors on the middle of the screen
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display issue (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further updates will be on my Facebook page.
Aug 17, 2011 | Toshiba REGZA 52RV530U LCD TV
Horizontal line in toshiba TVs
its the horizontal output IC
Feb 14, 2010 | Toshiba 28N33 28" TV
Toshiba TV (about 7 years old)
You had parts in the vertical deflection circuit failing, most common are the vertical output IC and possibly several capacitors also in the same circuit.
Sep 11, 2009 | Toshiba 36A50 36" TV
Toshiba Picture Not On
what you suggesting is that the lcd has a good maintenance needs that have to have cold solder or connectors are sulfated
Aug 22, 2009 | Televison & Video
Screen black no sound or picture with line in center
this is a common problem,the vertical hold has been damaged.dont leave the teli. on,the white line will burn the middle of the screen and leave a black mark. You need a new integrated circuit(i.c.) for vertical hold.
Mar 17, 2009 | Televison & Video
No picture only sound, Toshiba 36A 36" TV tube type
my friend if you open the tv carefully look to see if the tube itself has light, or if you have high voltage i coulbe many different things.wish luck!!
caypianan@yahoo.com
Aug 10, 2008 | Toshiba 36A50 36" TV
Picture reduced to a horizontal line across center
sounds like the vertical, more info ctechnicians.com
Dec 21, 2007 | Hitachi 35UX80B 35" TV
Toshiba 42hp83 plasma power supply problem?
I had the same problem. It turned out that one of the cooling fans get dusty and does not work. I opened the back of the Toshiba plasma TV and cleaned the failed fan, and it worked like a champ.
Nov 05, 2007 | Toshiba 42HP83 42 in. HD-Ready Plasma...
Vertical black lines rear projection
Please provide exact model from back of tv........
Possible vertical IC circuit problem===bad caps? IC?
...........T.
Nov 01, 2007 | Hitachi 50UX57B 50" Rear Projection...
Televison & Video Logo
120 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
