Where do I buy a LG WM3677HW drain hose? My hose is broken and leaking! Thanks
    Problem Solver:
  • 19 Answers
Saudamini electricals pratap nagar gurgaon
Posted on Jul 23, 2009
I replaced the hot & cold water valves on my LG Washer/Dryer .Now it just humms and no water goes into the washer..What can cause this problem?
have you tried both the cold and hot?hot only has one solenoid while the cold has three.just because it is a new part dose not mean it is not mean it is a good part.try this,turn off the cold and hot water,remove the cold hose from the washer and put it in a bucket and turn it on at the hose bib.if you do not get water,you may have a screen in the hose bib end of the hose.if no screen on that end you may have a metal fitting rusted up just under the hose bib.check the hot side also.hope this helps,if not repost and i will try to dig deeper.thanks
Mar 15, 2014 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
We heard a loud gushing sound and the dishwasher leaked all over the kitchen floor. Why?
The drain hose may have disconnected from the dishwasher or at the waste trap or the drain hose maybe broken.
If the drain hose is OK then the water supply hose may have disconnected from the tap or the water hose is broken and fresh water is leaking from this hose.
Jan 03, 2013 | LG LDF6810ST Stainless Steel Built-in...
LG WM3677HW all in one washer dryer water not draining and have cleaned out drain filter. what now?
i had the same problem turns out it was a pressure sensor. as water fills it the tub air gets pushed into this sensor to fill to the appropriate level or to drain.
Feb 23, 2011 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
What fault is E1
it means excessive r.p.m.'s of the wash motor during a wash cycle due to water leakage due to a leaking drain hose,the drain hose is not over 20" to the drain,a broken pump impeller,a damaged motor water sump seal
Nov 18, 2010 | LG Dishwashers
Lg wm3677hw combo washer drain pump repair question
You replace the whole drain pump. Pretty easy to do from the opening in the bottom by resting the unit on its back. (Make sure you drain the unit completely) You should be able to get the drain pump (pt #4681EA2001D) from http://www.encompassparts.com/lgconsumer/ for less than $50 + s&h.
Aug 31, 2009 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
LG washer/dryer combo will not drain water
easy first unplug unit..take back remove phillips head screws...now the pump drain hose is the other side of the filter in front just take a pliers remove clamp,,replace hose..close unit plug back in
Aug 18, 2008 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
LG Top Load Washer
this could be a drain hose loose or broken if the leak only occurs during rinse. If it leaks all the time, could be a broken outer drum or worn tub seal.
Hold inner drum and turn bothways. If it turns bothways, you have a bad bearing, and hence, a bad tub seal. If it turns in one direction only, bearing's good; but tub seal could still be bad.
Jul 17, 2008 | LG WFT1071TP Top Load Washer
Washing Machines Logo
96 people viewed this question
Top Washing Machines Experts
