My whirlpool lsc5000pq2 does not advance into the spin cycle
The washer keeps running water into the the tub but does not advance into the spin cycle, I have to manually advance the timer to finish a load. I have already replaced the motor coupler.
    Problem Solver:
  • 19 Answers
This the problem of Water Level Selecter switch bt 1st u clean the hose connecting W L S & Main TUB.POUR some cleanig liquied like Harpik from the top edge & let it go in side the tub. It is basically chocking/blockage problem which make disturbance to give proper air pressure to W L S switch.
Posted on Jul 23, 2009
Washer sticks on wash cycle; runs continuosly on spin cycle
That sounds like you have one of them fancy water saving outfits with a diverter valve that dumps the pump water continuosly over the clothes. Weirdest washer I ever saw. Could be the solenoid that opens the drain pump has failed. Don't know too much about em but I do have the service manual. Post your model number for a more precise answer. Whirlpool Catalyst washer manual
Apr 24, 2010 | Kenmore 24032\24036 Top Load Washer
Will not totally spin
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 16, 2010 | Whirlpool LSR5132PQ Top Load Washer
I have a Whirlpool Ultimate Care II Washing Machine. Lately, the spin cycle does not remove all the water. How can I fix this? Thanks. Bill
Jan 09, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag washer will not cycle.
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Jul 14, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Dryer will not start
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Mar 14, 2009 | Whirlpool WFW9400S
Whirpool Duet won't spin clothes at high speed
Thinking of 2 things either the transmission is out or the clutch is burnt out and the drum basket and possibly the drive shaft broken as well. Prices vary greatly by how many of these things are broken but should run between 100-200 including labor.
Dec 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
On my whirlpool top load washer lsc5000pq2 water keeps dumping and will not kick in to spin
Check motor coupler between motor and gearcase. It probably is broken, To replace remove pump and then remove motor, remove old pieces of coupler and install new one, reassemble in reverse
Dec 04, 2008 | Washing Machines
GE Top Load Washer WLSR2000G3WW~smells like burning and wont drain
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Nov 06, 2008 | GE WBSR3140DW Top Load Washer
Front loead washer will not spin/rinse,
First, make sure that you do not overload the machine.
Sep 17, 2008 | Frigidaire ATF6000ES Front Load Washer
Roper(whirlpool) washer will not spin
check the tub casting under the agitator or it the gearcase
Mar 17, 2008 | Roper RAX4233PQ Top Load Washer
Washing Machines Logo
176 people viewed this question
Top Washing Machines Experts
