Question about Toshiba WC-FM2 Remote Control
Same thing! Remote doesn't want to work
I have the same problem. On occasions in the past, the remote simply quit working. Then, a few days later, it would work just fine (I didn't watch a lot of TV in those days). I've only had the entire system a year, but I don't know what to do. It won't turn on or turn off the TV, I can't change channels or adjust the volume--nothing.
Try cleaning the infrared LED on the PC board. I had the same problem (10 year old Toshiba). LED was cloudy with dust- also clean inside the TV where the light comes trhough. Works fine now
Posted on Aug 17, 2009
    Novelist:
  • 133 Answers
Check the battery contacts for any oxydation, if there is any, scrub it off with a knife or a piece of sandpaper.
Next thing, check if there are any wires from the battery compartment to the circuit board and see if they are ok, resolder if broken.
If the battery contact tabs are soldered directly to the circuit board, check the solder connections and resolder if necessary.
Also check the IR LED (infrared light emmiting diode) on the front of the remote, see if the solder contacts are ok, if not, resolder (some remotes i've repaired had broken solder contacts on the emitter LED so check it out well).
Check any other components that are soldered on the circuit board for bad solder contacts and resolder if necessary.
Just in case, cleaning the rubber pads and the circuit board with some ethyl alcohol might do some good (let it dry thoroughly before reassembling it).
Hope you can get it working...
regards
3rq8 (Triarcuate)
Posted on Jul 24, 2009
2 Suggested Answers
SOURCE: My volume up on the
If the buttons used to work then yeah it sounds like a hardware issue. You can go ahead and take the remote apart, but I don't think you will be able to fix it, unless you are good at soldering. Cleaning the contacts alone won't help. This same thing happened to the most used buttons on my Harmony One, and I just assigned the commands to the screen, so I could continue using the remote without those buttons.
If you want to try assigning the buttons to the screen, the steps in this article by Logitech will help:
http://logitech-en-amr.custhelp.com/app/answers/detail/a_id/9766/kw/buttons
I hope this helps.
Posted on Aug 17, 2011
My tv control doesn't work and i put new battery's in and that didn't work either
There's a quick test you can do to test the functionality of the remote to make sure it isn't the TV's IR sensor that's broken. To perform the test all you need is the remote and a digital camera (cell phone cam works too). Take the remote and look at the IR "eye" through the camera's screen. Don't actually take a picture simply use the camera as you would a magnifying glass. While looking at the IR eye press a few buttons on the remote. If the remote is working you should see light coming out of the remote. Our eyes cant see the IR light but the camera can. If the remote doesn't light up then the remote is at fault. You can replace your remote on many websites for somewhere in the 20 - 50 dollar range.
http://www.replacementremotes.com/
Here for example, you need to input your TV model number and it will tell you what remote you need with pictures. Then, once you are sure that is the remote you want, you can order right from the same website.
Hope that helps!
Jul 19, 2011 | Televison & Video
Access system for 3/4 hp belt drive works sometimes, however with change in temp, climate conditions, the system does not work at all. a few days later the system will work without any adjustments
Some electronic components become sensitive to temperature changes and will quit working. If you have more than one remote unit and the problem exists with them all then your logic board is bad.
Oct 25, 2010 | Sears Craftsman LiftMaster Chamberlain...
Onkyo RC-729E remote for a DS-A3 iPod docking station. The remote seemed to work sometimes when I first got it. Few days later it does not work at all. Have tried changing batteries. Any other things...
The issue turned out to be that the iPod was not seated in the dock correctly. The adjustable back was adjusted too far forward so it was docked improperly. Correcting this corrected the remote issues. Everything works great now.
Jan 03, 2010 | Onkyo Televison & Video
My garage door remote will work for a day or two then it quits and then I have to reprogram it, and it works another few times and stops
If you only have one remote it could be it or the receiver that is quitting. No way to tell without another remote to test it.
Dec 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
LE26R74BDX TV Not responding to Remote
there is a easier way to check your remote.
Open your radio on AM frequencies, you don't need to be tuned just noise is perfect, then bring your remote near the antenna and press some button. You will ear the frequency in your radio. If it works this way but not on the TV make sure to press the TV button before using it (if the remote is universal).
Jul 01, 2009 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Door locks quit working
check battery in the remote
May 10, 2009 | 2006 Chevrolet Tahoe
Power windows, locks, dome light, and remote locks not working
Try checking the ground wires. They become corroded or loose and crazy things begin to happen.
Battery to frame and body to frame.
Be sure they are clean and tight.
Apr 11, 2009 | 1999 Jeep Grand Cherokee
Keyless remote only works part of the time.
I had the same problem only a few months after I bought the car new in 2003. Dealer fixed it. Then 6 months later same deal. Finally I went to a 3rd party and ordered new different brand remotes and figured out the programming which was quite simple. A serirs of procedures with the door and the key which programmed the devices. 5 years later no problems. Of course before you do anything try replacing the battery in the remote.
Mar 09, 2009 | 2003 Suzuki Aerio
Keyless remote
it might just simply be the battery of the remote died,
Nov 02, 2008 | 2001 Pontiac Aztek
Televison & Video Logo
351 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
