SOURCE: returns to standby
Green flashing 3 times = digital DC - DC converter fault
Red flashing 3 times = scan circuit fault
SOURCE: TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
SOURCE: Fujitsu Plasma Screen won't power up
This is most likely caused by the Main Power pcb.
See Fujitsu Service Bulletin on this problem in a similar model from Fujitsu. -see link below
http://tomtom2k5.free.fr/fujitsu/PDP-0035-06.pdf
A competent service technician should be able to implement the service bulletin.
A similar service bulletin is probably available for your model.
Request bulletin from Fujitsu '[email protected]'
SOURCE: Digistar PH-4210D Black Screen
Plasma tvs do not have "back lights" LCDs do. you probably have a bad driver board along with the upper or lower buffer board or maybe both, best to have a tv shop look at it.
SOURCE: Vizio plasma. screen went black, and the power light went out.
Sounds like the power suply went. I don't know that model off the top of my head, but you might find a replacement here http://www.electronica-usa.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=EU&Category_Code=PLA
-=/ Daft Tech /=-
