Too much green on tv screen
I have a zenith 32'' tv and can adjust the right colors but the screen still has too much green no matter how much you adjust it.
  • 2,359 Answers
How old is this 32" Zenith TV?
Since you did not post the model number......I'm going to assume it is a CRT tube type TV.
On an older TV set the green tint is an early warming sign for color calibration (by a professional).
They has test card / pattern generator and color correct tools to get the job done right.
There are something you can do to make sure it is not a magnetic problem.
Check the rear,top and side for any possible source of magnetic field.
Example: speakers,metal plates,or large CRT monitor or tube TV on the opposite side of the wall.
Try to do a quick clean up and see does it make any different.
If you are handy. You can use open the bad of the unit to blown out the duty with a can of compress air.
PLEASE BE REAL CAREFUL. DISCONNECT THE POWER.
FOLLOW THE CORRECT PROCEDURE TO DISCHARGE THE HIGH VOLTAGE FIRST.
Use a can of compress air to clean the TV from to down.
When you get to the boards,make sure you check for damage component like leaky/leaked (look for mark on circuit board) electrolytic capacitors and crack resistors.........
The chance are you will need a color calibration by the professional.
You should check their rate first and see is it worthwhile to go ahead with the service.
A 32" energy efficient LCD TV is only starting at $348.
Good luck.
Posted on Jul 23, 2009
  • 30 Answers
How old is the tv. did this happen suddenly or over time? also try adjusting tint that might work
I own a Quasar SP-3235 32" TV. It has a slight green tint after 10 years of use. How can I adjust the color screens on this set? Is it a function of the remote like Sony TVs or do I need to remove
I would open it first and look, a lot of those had both the screen and drive controls on the PCB at the end of the picture tube, at least look there first.
You are dead on in looking for the screen controls, if you find one it should only be a tiny adjustment due to age and the Crt changing a bit.
Dec 13, 2012 | Quasar SP-3235 32" TV
Zenith 32" TV picture is larger than the TV screen size.
Adjust the Aspect ratio. The manual will tell you how.
Feb 02, 2010 | Zenith A32B84R 32" TV
My tv is blurry, showing green and red waves...zenith d61w25
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic2_bing.gif,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 01, 2009 | Zenith D61W25 61" Rear Projection...
Samsung HCN4727W Rear Projection TV, green screen, audio works
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
*Screen Looks 3-D
*Colors wont align
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
Zenith 32" TV Chirping Noise No Picture
Components in Power supply are bad most likely a 35v 100ufd capacitor if not then your Flyback transformer is bad
Jun 09, 2009 | Zenith IQB32B42W 32" TV
Screen shrinkage
The vertical shrinkage is a fault in the vertical deflection circuit, suggest replacing capacitors around that area along with a vertical output IC. I can provide more info if you've got some electronics experience and going to try and tackle it.
May 18, 2009 | Zenith Televison & Video
Zenith R57W46 bottom bowing and color off and double lettering
Projection TV sets have two very common problems listed below.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
*Screen Looks 3-D
*Colors wont align
Mar 28, 2009 | Zenith R57W46 57" Rear Projection...
Blueand dark when picture should be yellow and gold bright
Well there are many causes for this. In the back of your tv there are three different color projectors. One red, one green, one blue. One or more of them seems to be out of alignment. They can be adjusted but it is recommended to be done by a professional as there are transformers in the back near that area that create the high voltage current needed to run the color guns.
Sep 15, 2007 | Zenith B32A24Z 32" TV
Color mostly green
Sounds like tyo me that the picture tube is getting soft on ya!!. Its a common factor that occours with all tvs but mostly with zenith. A service tech might be able for a small fee rejuvinate the picture tube but theres never a warrantee with this type repair. Its not something a user should attemp to do as theres hi voltage inside this set even on the tube socket after its ubplugged for awhile. Seek the advise of a repair pro to see how bad the tube is. Good Luck
Jul 02, 2006 | Zenith A27A23W 27" TV
Televison & Video Logo
668 people viewed this question
Top Televison & Video Experts
Electro Med Services...
