Question about Zanussi ZEBF250W Bottom Freezer Refrigerator
Freezer getting ice build up cold at bottom warm at top
I cleaned all coils and defrost it but a week later it is froze up again fridge is not very cold at all
  • 10 Answers
The problem is caused by frost build up on the freezer evaporator which is behind the rear plastic wall inside the freezer.the likeley cause is the defrost timer this is located at rear of the machine to the left of the compressor it is mounted in a white box secured to the cabinet ,two screws secure the box and two secure the timer to the box remove the four connectors from the timer there are four small philips screws in the timer once removed the cover comes off the timer inside there are four sets of contacts if any are black you can be certain this is the problem get a new timer this will cure it .if the contacts are not black, the problem is to do with the sealed system gas,compressor,evaporator etc .if this is the case cut your losses buy a new one
Posted on Jul 24, 2009
What is the problem when the fan is working on a fanussi zebf250w fridge freezer air cooled and there is no air coming up through vent into the fridge compartment to keep it cool
Posted on Oct 08, 2010
  • billmasterso Sep 17, 2011
    bad engineering and design,what recourse do i have to have it replaced with a proper working fridge , it was replaced once before and the same problem is happening again , i am dissanchented with the zanussi brand unfortunately. billmasterson@hotmail.com
How do I fix my GE refrigerator?
Ge uses a glass heater and it is common for the heater to go out replace the heater and it should cure your trouble
Dec 27, 2015 | GE Refrigerators
Top fan is blowing and freezer or bottom fridge is not getting very cold
Since neither is getting cold enough, I would start by cleaning the condenser grill under you unit and making sure you have good air flow across it. Even if that is not the problem, this will help your unit work more effeciently, and allow the coolant heat to be disapated.
The most likely cause though is the defrost circuit. If you remove the inner back panel in the freezer section and find a lot of ice around the evaporator coils then that is the most likely cause. NOTE: If it is the defrost circuit, then manually defrosting the unit will get the unit working for about two weeks before the ice build up happens again.
The defrost circuit is made up of the defrost heater, defrost thermostat (both located in the freezer section close to the evaporator coils) and the defrost timer (newer units have incorporated it onto the control board) that is located either in the fresh food section or cabinet control area.
Jan 07, 2012 | Maytag MTB2156GES Top Freezer Refrigerator
Hi We have a whirlpool side by side no ice maker in the past week the freezer is cold and frosty fridge is warm up to 15degrees at the top bottom of fridge is 5 degrees. Top vent from freezer is not in...
3 things
If you have ice on the freezer side.
1. defrost timer not working
2. blower fan failed, if it has one
3. defrost limit switch failed..
i dont think it is #2 but 1 or 3
last but not least your defrost heat coil has failed
Dec 18, 2010 | Refrigerators
Freezer iced fridge 50 F
You obviously still have a defrost problem so here is info to help solve it.
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Apr 21, 2010 | Hotpoint (HSM25IFTSA) Side by Side...
Defrost works fine but ice builds up in return air channel and fridge gets warm. model 106.55622500. Fan Ok, no ice on coil after defrost defrost timer ok. settings on middle of range after 3 weeks ice...
Hi!!
You may have the temp. set TOO HIGH for the freezer, set it in #2, leave the fridge setting in the mid range for now. Check after 24hrs. and adjust as necessary.
Good Luck!!
Mar 20, 2010 | GALAXY Microsystems 25.4 cu. ft....
I have a Kenmore side by side purchased in 1/2002. The freezer section keeps melting and then refreezing again. The ice creams melts then hardens up again. Please assist with what the problem may be. We...
It may be the defrost thermostat...
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
Sep 21, 2009 | Refrigerators
Ice build-up in lower freezer. We replaces the
warm between doors is normal. if hot then clean coils and if coils clean make sure condenser fan motor working thats the fan in the back compartment, however if warm thats good. did the evaporator coil freeze from top to btm is that why u replaced heater. if it was then could be heater,if the coil is only getting frost on half the coil,you could have a sealed system problem. is the evaporator motor working in the frz side if not,then that could be the problem.if coil is froze up it needs to be defrosted. did you defrost coil when you replaced heater,if not try defrosting coils and then wait about 12 hrs and see how it does.
Sep 16, 2009 | Maytag MSD2756G Side by Side Refrigerator
WHIRLPOOL TOP FREEZER ET1WTKXKQ01. NOT COLD ENOUGH & KEEPS RUNNIN
remove the back wall leave the unit to run half hour open and see if coil have frost all the way from the top of the coil to the bottom if the coil is full you have adefrost problem could be your timer defrost thermostart or heater
Mar 31, 2009 | Whirlpool ET1WTKX Top Freezer Refrigerator
Maytag side by side model GS24C8C3EV Refrigerator too warm
it is almost certainly a defrost problem. when fault has occured, remove freezer bzck panel and see if there is ice build-up. if so this confirms a defrost problem - possibly that the element is open circuit
Jun 21, 2007 | Maytag MSD2434GE Side by Side Refrigerator
Zanussi ZEBF250W Bottom Freezer Refrigerator Logo
1,095 people viewed this question
Top Zanussi Refrigerators Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Jason Harris
Jason Harris
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
