SOURCE: TV screen will darken from the bottom to the
This would appear to be a problem with the backlights in the screen. If it looks like a dark shadow effect then the backlights are no longer filling the screen with a uniform amount of light.The only cure for this is to have the screen replaced.
SOURCE: tv screen darkens at night
The set likely has a light sensor on the front of it to change brightness with light changes in the room, if not in the menu to switch on or off contact LG to see with the model number what can be done.
I have seen some where the sensor had to be disconnected inside to correct this issue. Sets as far back as 50 years ago had this issue.
