Question about Hobart LXiGC Dishwasher
Dishwasher calls for detergent & rinse
Our commercial Hobart LXI dishwasher will scream and call for detergent & rinse. It will work for a few days and then it will start in again. We changed the squeeze tubes but it still persists. Sometimes if we run it through a few cycles it stops but then for no reason it will start up again. I have called serveral repair services and they don't seem to want to work on it. Any ideas?
    Scholar:
  • 109 Answers
I take it, the screaming is a beeping sound from the detergent alarm feature.
The chemical tubes from detergent and rinse run through a sensor board on the rear of the machine. If there is an interuption in the flow, or an air hole in the tube, or wrong chemical, it will trigger an alarm..
Is there a chance when replacing the pump tubes, that they were installed in the wrong direction? They should feed in on the bottom, run clockwise and discharge at the top. Check for restrictions in the flow.
Posted on Oct 05, 2009
Water continues coming
Hobart ' Undercounter Dishwashers, Commercial ...
www.hobartcorp.com/.../commercial.../undercounters...
Hobart CorporationGlasswasher ... The LXe undercounter is ENERGY STAR® qualified, uses only .74 gallons of water per cycle and features new Smart Display technology to eliminate error codes. Loading... Highlights: Hobart undercounter dish machines are the most popular in the industry, keeping reputations spotless all over the world.
Advansys LXe Undercounter ' Hobart
Hobart CorporationGlasswasher ... The Hobart LXe Undercounter Dishwasher is designed to pack best-in-class cleaning power into a compact space, ... The Advansys LXe low-temp model features PuriRinse, a cold-water rinse that removes chemical residue, ...
[PDF]AM15 Technical Manual - Hobart
https://my.hobartcorp.com/kroger/.../AM15%20Technical%20Manual.pd...
Steam Booster, if used based on 20 PSI steam - 20 PSI water flowing. 130°F entering.... DRAIN AND OVERFLOW: Large bell type automatic overflow and drain ...
[PDF]Glass- and dishwashers - Hobart
Dec 08, 2015 | Hobart Undercounter Glasswasher w/Chemical...
My lxi-h won't draw rinse aid through the pump
You need to replace the squeeze tube on the rinse aid pump
May 23, 2013 | Hobart Undercounter/Lxi Warewasher 24"W x...
Hobart LXI-H rinse doesn't work
water flow pressure needs to be a min. of 15 PSI..
Apr 26, 2012 | Hobart 25 in. LXIH-4 Built-in Dishwasher
What type of detergent is used for a lx30c hobart undercounter dishwasher
What type of detergent is not necessarily important - anything intented for use in commercial dishwashers should be sufficient. A restaurant supply store should have something suitable for you.
Also, in case you don't already know, the LX30C is the non-booster-heater version of the LX30 (LX30H has a booster heater). Without a booster heater, you'll need to use chemical sanitizer. The LX30C should, hopefully, have a sanitizer pump installed to inject chemical sanitizer into the rinsewater stream. Most of these dishwashers also have a detergent pump to inject detergent into the wash tank and rinse aid pump for chemical rinse aid.
If present, these pumps are located in the bottom of the machine. Remove the lower front panel (2 screws) and look for the small, black plastic assemblies with 2 hoses connected to each.
Mar 13, 2012 | Hobart 24 in. LXIC-5 Built-in Dishwasher
I have purchased a business - with a Hobart LXi - and no manual. I can't figure out what soap etc to use - or how it gets into the dishwasher!
Contact your local chemical supplier such as EcoLab or AutoChlor to purchase the proper chemicals. Use ONLY commercal dish washing chemicals. Residential detergents like Cascade do not dissolve fast enough and WILL, in time, cause you trouble if used in the LXi.
There should be three colored plastic tubes at the rear of your machine. Red is to be put in a container of liquid detergent, Blue is for rinse aid, and white/clear is for sanitizer. Your chemical salesman should be able to show you how it's done at no charge.
You may also want to register here http://www.hobartservice.com/Manuals/ then download the manuals for the LXi dish machine.
All the best.
Nov 28, 2009 | Hobart LXiGC Dishwasher
Hobart LXI
Question--As of today if you look at the display does it read add detergent or add rinse aid?Im asking you this because theres a chemical pump circuit board that senses the chemicals on this d/w.And if the d/w displays those the d/w will keep dumping det/r.a. in.Let me know,if this is not the issue i will get you into the service program and step you thru.
Nov 14, 2008 | Dishwashers
Hobart LXiGC Dishwasher Logo
404 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
