Question about SanDisk Sansa m230 MP3 Player
Computer does not register Sandisk Sansa m230 MP3 Player
I have had my m230 MP3 for years. It has always worked fine before now. All of a sudden my computer will not register my MP3 when it is plugged in. I am utterly baffled!
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out:
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
SanDisk Sansa M230 Problem:When connected to my PC and try to open system says " this device is not formatted. Do you want to format it now?" . If "yes" is selected then system says it...
Connect your SanDisk Sansa M230 to your computer again. Ignore the format message and go to My computer icon on your computer, right click on the drive (E:or F: or G: etc) representing your SanDisk Sansa M230, scroll to format allow it format from there.
If it still refuses to format, you can the reset the SanDisk Sansa M230and try again.
In case you don't know how to reset your SanDisk Sansa M230, read the info on the below link on how to reset your SanDisk Sansa M23;
I hope this helps.
Good luck.
Feb 22, 2011 | SanDisk Sansa m230 MP3 Player
Will my mp3 player (sandisk sansa m230) charge
Assuming the computer puts out enough juice, yes. Not all USB ports do.
Plug it in, and the Sansa should say "Charging" if it is charging. If it doesn't, try a different USB port if possible. If your computer has ports on the front/side and on the back, the back ones are more likely to put out sufficient power.
Apr 29, 2010 | SanDisk Sansa m230 MP3 Player
Sansa m230 not syncing music files or downloading them. Process leaves the Sansa m230 with 0 files and i am finding it impossible to load new file(s) ?
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturer?s website. Make sure that you back your music up first because when you do this you are setting it back to factory settings. Then add music this way and see if it is works: 1. Free a USB port on your desktop computer. Now, grab the USB cable for your SanDisk Sansa MP3 player and connect the player to your computer. 2. Wait for your computer to find and recognize the player. This may take a few moments. Once you receive a confirmation message, open your computer and scan the icons for the SanDisk MP3 player. 3. Open the SanDisk Sansa MP3 player on your computer. The music files that you currently have saved to the player?s memory are displayed. 4. Open a folder containing music files that is stored in your desktop computer?s memory. Scan the files for songs that you want to transfer to the SanDisk Sansa MP3 player. 5. Left-click on a song file and drag to the SanDisk Sansa window. Drop the file and let your computer complete the transfer. The transferred file appears at the bottom of your music list. 6. Unplug your SanDisk Sansa player from your computer. Turn the player on and allow the file transfer to update to the internal memory of the MP3 player.
Oct 01, 2009 | SanDisk Sansa m230 MP3 Player
Reseting my sansa m230 mp3 player
You can reset the player by removing/reinserting your battery.
Here is alink to your user's manual:
-Tha Mp3 doctor
Mar 16, 2009 | SanDisk Sansa m230 MP3 Player
SanDisk Problem
Sandisk website has the software
Apr 09, 2008 | SanDisk Sansa m230 MP3 Player
Sansa M230 not seen in Explorer or Windows Media Player
We had the same problem with Windows XP. We found some help on the Sandisk web site. On the device go to the Settings menu, then USB. We changed from AutoDetect to MSC mode and everything is working again. Our computer saw all of the songs on our computer fine. Some of the old songs on the Sansa didn't show up on the detect list in Windows Media Player, but they were still on the device.
Mar 23, 2008 | SanDisk Sansa m230 MP3 Player
Sansa m230
It sounds like there is a problem with the sandisk and have them do a firmware upgrade on the device...once you do that it should fix the problems you are having right
Dec 16, 2007 | SanDisk Sansa m230 MP3 Player
All of a sudden all the files on my sansa m230 disappeared.
your not using the correct program! you use windows media players. its most recommeded from sandisk. go to the sync section and on the side bar there'll be like a read snasa m30 right click on it clcik format media. then go to the sync section and drag the files u want in to the lil box and click sync
Apr 03, 2007 | SanDisk Sansa m230 MP3 Player
My mp3 player doesn't work
My Mp3 dosn't work when i turn it on it says updating and when i put it on the charger it tells me instalzing i don't know what to do please help me.
Nov 27, 2006 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa m230 MP3 Player Logo
43 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
