Question about Intermatic T103 Indoor 120-Volt 40-amp Timer Switch-Double Pole/Single Thro
How are the wires for the pool and heater pumps go on
    Genius:
  • 1,043 Answers
Here is a link to a pdf version of the wiring diagram for a T103. Hopefully this will help you.
http://www.progressive-growth.com/wiring/T103.pdf
Posted on Jul 23, 2009
  • bvanjoff Jul 24, 2009
    Please let me know, when you have the chance, if the link I provided gives you the information you were looking for. Thank you.
SRS Rite pool heater turns on by itself when pump is running. How do I prevent this from continuing?
Pool heaters are wired through the pump so that they don't turn on when the water is not moving. But that doesn't mean they have to run all the time the pump does.
The heater should have its own On-Off switch. Find that and turn it off. It may be hidden under a cover to protect it from the rain.
It also should have a thermostat. Find that also and set for a comfortable temperature. It may take some fiddling because the water will be hotter by the jets than the rest of the pool until it circulates and stabilizes at a uniform temperature.
You should be able to find both the On-Off switch and Thermostat near the removable panel that allows access to the guts of the heater. Should also be a wiring diagram inside the panel to assist in finding the controls.
On the off chance that someone (previous owner?) bypassed the controlls you may have to rewire the heater so that they work as originally intended, or install a new switch between the pump and heater.
If this was helpful, please rate accordingly. Thanks.
Jul 05, 2016 | Pool & Spa
How to set raypak heater to remote
hold down mode button or scroll to remote make sure wire from control system is connected to pool spa com if pool only only need pool and com
Sep 29, 2014 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Hayward heating pump won't ignite.
if new and wired for 120 voltage reverse black and white wires if reversed they wont show rectafication if old heater replace or clean up flame sensor
Sep 21, 2014 | Hayward H - Series 400 Heater Top for In -...
Raypax 2100 pool heater will not stay lit?
dirty or bad flame sensor if wired 120 volt try reversing black and white wire
Sep 01, 2013 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
How to wire controls for a raypak heater to a compool lx3600 controller
if it is three wires see which wires are connected to main board one should be on each pool spa com match tose and heater should work make sure to put heater on remote
May 19, 2013 | Pentair Pool & Spa
Does the pool pump need to wired into the Jandy heater for the heater to work?
no if using a aqualink yes firemans switch to pins 1 and 2 on long green or gray plug if no aqualink the pressure switch will turn it off
Jun 15, 2012 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Can I wire my heater to my pool pump timer. I want power to the heater only when my pump is running.
If your heater is operating properly, it will not heat if your pump is not running. But you can connect it to your timer also. How you do it will depend on what type of time you have, Which model of heater you have. If you have your manual, you can find wiring examples for your heater.
Jul 17, 2010 | Hayward H Series Pool & Spa Heater 400k...
I need to run the filter pump without power to the heater
dont worry about the heater it will not come on so turn the pump on before it turn green call a pool guy
Aug 17, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Intermatic T103 Indoor 120-Volt 40-amp Timer Switch-Double Pole/Single Thro Logo
115 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
