Question about Garden
Sears lawn tractor 917256491 unable to activate start solenoid.
I have tested the solenoid and it works. I have replaced the start switch. I have activated all the proper safety start switches. The solenoid won't even click with it installed on the mower. I don't have a wiring diagram. Is there an easy way to isolate the trouble from this point.
    Sniper:
  • 53 Answers
First see if u can jump the started with a screw driver, also check fuse could be blown. do u have battery voltage? here is a site for a wiring diagram www.managemyhome.com.
Posted on Jul 23, 2009
My john Deere 110- 42" cut lawn mower ran out of gas and won't crank back. Noticed the parking brake is engaged but will still roll. What is my problem?
Hi Shannon, It's either fuel OR electrical, First check electrics, If it cranks but not starting......
How to test a solenoid....
How to test lawn mower solenoid
How small engine governors work....
How Small Engine Governors Work any governor setup
How to test lawn mower electrical safety switches....
Shows all safety switches disabled....
Disable all lawnmower safety switches
Apr 29, 2016 | John Deere Garden
Why after using my Kubota b2601 tractor I shut it off and when I went to start it all I get is one click
Hi Wilbur, The links below are YouTube videos that might get you out of trouble... Also there's videos down the right side of the links that may help as well....... I hope they help......... CHEERS....
How to test a lawn mower Key switch....
How to test lawn mower key switch
Apr 28, 2016 | Kubota Garden
Wont start
Hi John, The links below are youtube videos that might get you out of trouble... Also there's videos down the right side of the links that may help as well....... I hope these help......... CHEERS..
shows all safety switches disabled....
Apr 25, 2016 | Garden
Why does engine cut back, even though the mower still cuts well?
Hi Anonymous, The links below are youtube video's, I hope this helps....CHEERS..
1st shows a craftsman mower with problems....
Craftsman Lawn Tractor stalling out
2nd shows a craftsman seat safety switch disabled....
Seat Safety Craftsman Disablement
3rd shows all safety switches disabled....
4thHow to test lawn mower electrical safety switches....
5th How to test a solenoid....
6th How to test a lawn mower Key switch....
Apr 16, 2016 | Garden
Sears Garden tractor does not start, how to i test to see if it is the starter or solenoid or what?
Try turning it over with the spark plug removed. If it now turns over the starter is weak and needs to be replaced. Also check the oil level. Too much oil will will lock it up.
Apr 14, 2013 | Craftsman Lawn Tractor Operators Manual...
Won't Crank Over with key, unknown if it will start
To start the tractor, current flows from the battery through the "start" contact of the ignition/start switch, then through two safety switches: one is activated by having the brake on (or by having the mower in neutral). The other is part of the PTO (engage mower blades) switch. I don't know which would come first on your mower, so get a test light or a multimeter and trace your way along this path. The current then goes to the small terminal on the solenoid.
Another possibility -- in changing the motor, did someone leave a ground lug off, or worse, maybe they just cut it off when removing the old engine? That would also prevent things from working. Good luck! If this is helpful, please rate it, thanks!
Jun 06, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
Won't start,the battery needle goes (-) when the key is turn to start
Can you hear the Solenoid click when to try to start? If not, I had the same problem it was the Solenoid. Sears insisted it must be the battery even though it was weak but not dead. Replaced the battery but it still would not work. Replaced the Solenoid and did the trick.
May 03, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
429 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
