Question about Polaris 380 In Ground Pool Cleaner
Wheels on polaris don't turn. Is there a way to tighten belts
I have a Polaris 380 that is 4 years old. The wheels turn together when the polaris is off but the belts seem loose.
  • 128 Answers
Replace the belts.($30) Tighten with an 1/8" play. Also check the wheel bearings. If the wheels wobble they also need to be replaced
Posted on Aug 23, 2009
Polaris 380 wheels not turning
see if filter at wall fitting ok then see if water coming out of jet on back
Aug 02, 2017 | Polaris 380 In Ground Pool Cleaner
The wheels on my polaris 360 don't turn
if pressure ok look inside and check hoses and belts and gears on wheels
Jul 25, 2011 | Polaris 380 Automatic Pool Cleaner with...
I have a polaris 380. I have replaced the belts and several of the bearings. The wheels all turn at the same time when you spin one of them, however when it is in the pool and I check the RPM it...
If all the belts, bearings, shafts, etc are in order and the wheels don't turn then the turbine is not providing power to the system. This turbine is under a cover inside the cleaner. Remove the cover to inspect it (look for any mechanical problems). You can also connect water pressure to it at this time to see if the jet that turns it will make the turbine turn. If the turbine is being hit by a jet of water it should turn if the friction in the belts, bearings, shafts, etc. is not too high.
Jun 23, 2011 | Polaris 380 In Ground Pool Cleaner
Polaris 380 wont run when vertical
The drive belts are loose. Replace the drive belts are at least take the cover off inspect and tighten. The adjustments are the axle blocks. Tighten to where there is about an 1/8" tension while lightly pushing on the belt.
Aug 27, 2009 | Polaris 380 In Ground Pool Cleaner
My polaris 380 wheels won't turn. the belt is
If the wheels don't turn there may be sand in the notches on the wheels, the notches may be worn off, if their is sand or dirt in the paddel wheel jet that will keep the unit from turning and again no wheel movement. All of these problems they can check in your local pool store. Stores will generely check your unit out and fix what is needed for just the price of parts to fix it when you bring it into the store.
If you have no water flow to the unit this will also stop things from working so be sure to check your finger screen before you do anything.
Aug 24, 2009 | Polaris 380 In Ground Pool Cleaner
Polaris 380
polaris has belts in side it if your handy you can replace them your self if not any pool place can do it but it is a belt i have a 380
Jul 21, 2009 | Polaris 380 In Ground Pool Cleaner
I installed a booster pump. Attached a one ince
1. debris in the water management system (hoses inside the cleaner)
2. black gears in cleaner need replacing (360/380)
3. belt kit (polaris 360/380) or drive shaft need replacing (180/280)
4. teeth on inside of wheels are worn out (polaris 180/280 only)
Jul 16, 2009 | Polaris 380 In Ground Pool Cleaner
Polaris 380 wheels not moving
Here are some things to check: 1.  There are belts inside the unit that drive the wheels.  These belts often fail (shred) and must be replaced. 2.  There is a paddlewheel that drives the turbine that turns the wheels.  If the jet that drives the turbine is clogged, then the paddlewheel will not move and the wheels will not turn. 3.  There is a water management system inside the bottom of the unit.  It looks like a bunch of little hoses.  If one of these hoses comes loose, then the water pressure will escape inside the unit and will not be sufficient to drive the wheels.
Hope this helps
Jan 09, 2009 | Polaris 380 In Ground Pool Cleaner
Polaris 380 In Ground Pool Cleaner Logo
638 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Michael Vincent Cruz
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
