Question about Comfort-Aire HD-301 Dehumidifier
I have a frigidaire dehumidifier model fdd2551 serial no kn85103158 and had it running for 4 days on co or somethin like that and now when I turn it on a day later it says as witch is a error code
Is there a recall on Frigidaire dehumidifier Model FAD504DUD
Some dehumidifiers with the model number, FAD504DUD, are subject to a recall. Record the serial number and then go to https://www.recallrtr.com/dehumidifier to check if your unit was manufactured in the bad batch.
Without the serial number, I can't be sure if your unit is in the 2016 recall. For details, you can look at https://www.cpsc.gov/Recalls/2017/Dehumidifiers-Made-by-Midea-Recalled .
I hope this helps.
Jan 26, 2017 | Frigidaire Dehumidifiers
My Frigidaire Model 50S1 dehumidifier purchased in May 2009 runs but is not extracting/collecting any water. How do I remedy this problem?
Hello friend, thanks for your inquiry!
I understand that your Frigidaire dehumidifier is running but not pulling any moisture. I would check the set point and if necessary set it to a lower setting. Attempt to run your appliance on "CO" which is for continuous drain to see if any moisture is pulled out of your room. If those steps do not work you may want to reach out to the manufacture to see if they have any potential remedy for your appliance. -Matt
Sep 11, 2014 | Dehumidifiers
What are the codes. i get co as a code. itruns but will not remove the humidity
CO just means it is in continuous mode, that is not a fault. It may take quite a few days to settle the humidity.
The codes are AS or ES which indicate sensor faults
Jun 21, 2014 | Frigidaire FAD704TDP Dehumidifier
How to measure humidity in a room
Good Afternoon Friend,
I understand that you want to know how to measure the humidity in a room with your Frigidaire dehumidifier, model# FDL50R1. Typically, your appliance will not measure the humidity and tell you exactly what the level is. I suggest placing your dehumidifier in the room you want it in, and turning it on to the continuous mode. The display will show "CO". Leave it at this setting for the first 3-4 days. Once the 3-4 days has passed, I suggest setting it to the 50%, 60%, or 70% setting and change it to your liking. If it is more humid in the room than you would like, put the setting lower. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 23, 2014 | Frigidaire FDL50R1 Dehumidifier
Frigidaire dehumidifier model # FDL50S1 clicking very loudly.
If the unit is not running fully, but you have this noise, sounds like the internal fan might be the culprit. Contact your manufacturer for further options.
Aug 24, 2012 | Frigidaire Fdl50s1 Air Purifier &...
Recently bought a Frigidaire Dehumidifier four days ago. Ran it for 3 days on the co setting as the manual instructed. When I set the humidity level, after about 5 minutes it shuts down...does not come...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jan 21, 2011 | Frigidaire FDL25P1 Dehumidifier
The humidifier runs but is not collecting water... so humidity level never drops.
My brand new frigidaire 50 liter dehumidifier has been on for two days and has not collected water from my damp basement. It is on the factory settings: high fan and "CO" (continuous).
Aug 10, 2009 | Maytag M7DH65B2A Dehumidifier
Dehumidifier runs but does not collect water
I have dehumidifier Whirlpoot Gold Model #39R171E Serial #H/XE11M1K 6203A it was working fine last year, but this year it is not collecting any water, it is running for day. I opened it, cleaned the filter (which was mostly clean) & it still has not water in bucket. What is wrong & is it possible to fix it by myself.
Jun 10, 2009 | Haier HDN655E Dehumidifier
Comfort-Aire HD-301 Dehumidifier Logo
480 people viewed this question
Top Comfort-Aire Dehumidifiers Experts
Mike Squire
Bill Long
Michael Youngman
Michael Youngman
Are you a Comfort-Aire Dehumidifier Expert? Answer questions, earn points and help others
