Question about HP Deskjet F2210 InkJet Printer
Cartridge cradle can't move, says paper is empty when it's not
My printer worked fine until I changed the cartridges the other day. I performed the alignment - great. Printed an assignment - fine. Then it totally FREAKED OUT.
The "E" flashes even and says there's a paper jam when there's not, says there is no paper when there IS paper, and now apparently the cartridge cradle cannot move... so I'm supposed to check for a paper jam or obstruction. No paper jam, no visible obstruction - what should I do?
  • 2 more comments
  • leahnsims Jul 23, 2009
    Nothin'... Still get "There is a paper jam (or misfeed). Clear the jam and press the Start Copy button on the printer." and the "E" flashing...
    any other suggestions?
    Nothin'... still get "There is a paper jam (or misfeed). Clear the jam and press the Start Copy button on the printer." and flashing "E."
  • leahnsims Jul 26, 2009
    Yes, the error happens as soon as the printer finishes powering up. (Thanks for your help, btw!)
    I tried doing what you outlined above... no luck. Tried to see if there is anything tiny in the paper path... but I can't see or feel anything. How do I eliminate the copy function?
  • Kevin Hughes May 11, 2010
    First try to totally disconnect from power. Turn off, and unplug for at least 5 minutes. Then reconnect and try again. Let me know.
I had this problem when i bought new carts, get the error message paper jam with on paper in the printer. i simply fix this problem by putting my old carts turn it off n on it n the error was gone.
Reply
Posted on Jun 29, 2011
    Scholar:
  • 82 Answers
OK....try removing the carts, close the printer, turn off, then disconnect...alot of the problems with the newer HP printers has to do with their ROM memory....if that doesn't work, then there is defintely something in the paper path, no matter how small. Try to eliminate the copy function....does the error happen as soon as the printer is finished powering up??
Posted on Jul 23, 2009
  • paz2mi Jun 29, 2011
    i had this problem when i bought new carts, get the error message paper jam with on paper in the printer. i simply fix this problem by putting my old carts turn it off n on it n the error was gone.
Replacing cartdiges in sx 200 epaon
Press the ink button on the control panel repeatedly. This will work if at least one cartridge is completely out. With the scanner unit open, then the first press of the ink button will move the cartridge carrier to line up the empty cartridge with an "empty cartridge" mark on the printer. Each subsequent press will cause the next empty cartridge to line up with the mark. Once all of the empty cartridges have been indicated, the next press of the ink button will bring the cartridges into the replacement position.
If you want to change a cartridge when none are empty, you need to enter the Epson Toolbox (with the printer in a Ready state - scanner unit closed, etc). Then use the software to set the printer to change the ink cartridges. When prompted by the software, open the scanner unit and follow the directions for changing the ink cartridges.
If the cartridge carrier isn't moving when you press the ink button, look for anything blocking the path of the carrier. Even small pieces of paper could stop the mechanism. Use a flashlight to check the corners. (You may want to unplug the printer and try moving the cartridge carrier by hand to check below it.) Some models have the cartridge carrier run on a plastic strip that can come out of the guide on the back. Move the strip back and up and down until it is repositioned.
I hope this helps.
Nov 12, 2011 | Office Equipment & Supplies
Colour ink cartridge not reconise. replace colour ink cartridge.cod 3603
To resolve the issue:
  1. Make sure you install the correct type of KODAK Ink Cartridge for your printer. Currently we offer two types of ink cartridges (10 Series and 30 Series). Installing the wrong type of ink cartridge may result in this error. You will need to install a new, correct type of KODAK Ink Cartridge.
    NOTE: For more information, see Which ink cartridges to buy for all-in-one printer.
  2. If you are using the correct type of KODAK Ink Cartridge, reinstall the color ink cartridge.
    1. Open the printer access door.
      NOTE: If the ink cartridges don't move to the center, see Printhead and ink cartridges don't move to center with access door open.
    2. Wait until the printhead is idle and silent, then pinch the latch on the color ink cartridge with your thumb and forefinger and lift it out of the printhead.
    3. Install the color ink cartridge back into the printer, making sure to press down on the thumb tab until it clicks into place.
    4. Close the printer access door. For printers with LCDs, follow the instructions on the LCD screen.
      For more information on installing ink cartridges, see the Extended User Guide for your printer. Review Maintaining Your Printer - Replacing ink cartridges.
  3. If the error continues, restart your printer:
    1. Turn off the printer by pressing the power button.
    2. Wait five seconds.
    3. Turn on the printer.
  4. If the error continues, and you have extra, new KODAK Ink Cartridges on-hand, try to install a new ink cartridge (or a set of new ink cartridges).
  5. If the error continues, contact us.
When the issue is resolved, we highly recommend that you upgrade the firmware for your printer for optimum performance:
  1. Locate and select the firmware for your printer.
  2. Follow the instructions to install the firmware.
Source: http://support.en.kodak.co.uk/app/answers/detail/a_id/39315/selected/true
Jun 07, 2011 | Office Equipment & Supplies
My HP Photosmart C4400 keeps giving me the message, "The cartridge cradle cannot move. Please turn device power off. Check device for a paper jam or other obstruction." Two days ago, early in...
sure
or paper scraps in side blocking key sensors or other parts
clean all that chaff out first.
blow it and brush and pluck it all out.
there is nothing simple on printers, and 10000 types.
if fails to work after all that , it needs service.
Mar 16, 2017 | HP Photosmart C4400 series
Paper feed not working. green button and orange
I assume you mean that the power and resume lights are blinking. This signals a carriage stall. Open the top cover, if the cartridge cradle moves to the right, it isn't stuck and may be a one-time issue. If it is stuck, unplug the power to the printer. Open the access door and observe the carriage position. Clean any lint or paper pieces out. Remove any obstructions. Move the cradle and continue checking for lint, paper and obstructions until the entire area is cleaned out. If the print carriage started out on the left side, return it to that position to make sure the cartridges are back in the capping station. Look inside the printer along the cartridge cradle path for obstructions and remove any. Remove the rear access door and check for paper pieces, remove any obstructions.
Plug in and turn on the printer and see if the carriage returns to the left and reseats itself in the capping station. Close up the printer.
If this doesn't work, the printer may need service.
I hope this helps.
Mar 28, 2010 | HP DeskJet 5740 InkJet Photo Printer
Green power light is flashing for no apparent reason
Solution
Close the cover.
Cause
Printer cover is open. Solution
Insert appropriate media in the In tray.
Cause
The printer is out of paper. Solution
  • Change the printer's print mode setting.
  • Change the printer's paper type selection.
  • Use a different brand of label media.
Cause
The printer has difficulty picking up label media. Solution
Follow each of these steps until the problem is resolved:
  1. Remove the paper from both paper trays.
  2. Press the power button once. Wait a moment for the paper jam to clear.
  3. If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
  4. Remove the rear access door.
  5. Remove the paper jam through the opening at the back of the printer.
  6. Replace the rear access door.
  7. Reload the paper into the paper In tray.
  8. Print the document.
Cause
There is a paper jam. Solution
  1. Remove and then reinsert the print cartridge(s) into the printer.
  2. Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
  3. Manually clean the print cartridges and print cartridge cradles:
    • Open the printer cover and wait until the carriage moves to the center.
    • Press the Power button to turn off the printer.
    • Disconnect power cord from the back of the printer.
    • Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
    • Lightly moisten a cotton swab with distilled water.
    • Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
    • Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
    • Reinsert the print cartridges.
    • Close the printer cover.
    • Connect the power cord to the back of the printer.
    • Press the Power button to turn on the printer.
  4. Calibrate the print cartridges.
  5. If the light is still flashing, replace the print cartridges.
Cause
There is a problem with a print cartridge. Solution
  1. Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
  2. Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
  3. Remove and then reinsert the print cartridge(s) into the printer.
  4. Print the document.
  5. If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
  6. Try printing again. If the problem continues, replace the print cartridges.
Cause
The print cartridge has partial loss of electrical interface with the carriage connections.
Jan 02, 2010 | HP DeskJet 3940 InkJet Photo Printer
HP DESKJET 3820 GREEN LIGHT FLASHING, WILL NOT PRINT.
Issue
Solution
Close the cover.
Issue
Printer is out of paper
Solution
Issue
Printer has difficulty picking up label media
Solution
Issue
Solution
  2. Press the Power button once. Wait a moment for the paper jam to clear.
Issue
Solution
Issue
Solution
Cyber kaka
Dec 08, 2008 | Office Equipment & Supplies
The print cartridge cradle cannot move.
"The print cartridge cradle cannot move."
I fixed this problem by disconnecting the power cord from the power-strip and connecting it directly into the wall. My printer was not getting enough voltage from the power-strip. I hope this helps.
Nov 18, 2008 | HP Photosmart C3180 All-In-One InkJet...
Change ink cartridge
Here is the procedure to change the ink cartridge
  • First Press the POWER button to turn on the printer.
  • Open the top cover.The cradle moves to the center of the printer.Open the cradle latch.
  • Slide the print cartridge out of the print cartridge cradle and discard it.
  • Remove the replacement print cartridge from its packaging and carefully remove the plastic tape. Hold the print cartridge so that the copper strip is on the bottom
  • Slide the print cartridge firmly into the cradle. Ensure that the copper contacts the print cartridge meet the copper contacts of the print cartridge cradle
  • Close the cradle latch.
  • Verify white paper is loaded in the printer, then close the top cover. The printer automatically prints a calibration page for optimum print quality.
good luck:-)
Oct 08, 2008 | HP Office Equipment & Supplies
HP Deskjet F2210 InkJet Printer Logo
527 people viewed this question
Ben Johnson
