Question about Panasonic PT-53WX42 53" Rear Projection Television
Panasonic PT-56DLX75 TV pops, turns off, and back on. This is crazy, but my landline non-cordless phone rings 2 shorts rings when the TV turns off. Don't know if related, but lamp replacement message has been on for several months when first powering up.
  • 3,037 Answers
Well, first replace the lamp, since it is most likely time and the pop is a symptom to replace it. Is your landline connected to the outlet and the phone because this is strange especially if it isn't connected to the outlet. Let me know how replacing the lamp goes.
Benjamin
Posted on Jul 23, 2009
Panasonic DECT 6.0 cordless phones system has begun dropping calls after first ring also won't take messages
Firstly, disconnect all devices / base unit from your landline. Then, using a mobile phone, dial your landline number. Does the ringing tone in the earpiece continue or does it stop after one ring? If it stops then you have a line problem which you need to report to your service provider.
Apr 27, 2017 | Panasonic Lands Phones
Phone rings once then cuts off. Can ring out OK.
Something has a shorted the line, unplug all phones, then call your line with a cell phone and see if it is still happening. If so, you will need to call repair. If not, plug 1 phone in at a time and call your number again, and repeat until you find the phone causing it to trip ring.. also if you do not have a inside wire maintenance agreement with you local phone company, start the test at the network interface device..
Aug 11, 2015 | Lands Phones
Hi, I have a Panasonic Cordless phone with 2 bases. I have moved one from upstairs to the phone jacket downstairs. Our third phone worked fine until I switched two of them around. Now only the plugged...
You could plug your non-cordless phone into suspicious phone jack to see if you have dial tone-if you dont have dial tone, the line maynot be connected and you should open the jack to see if there is more than 1 cable attached. If there is more than 1 cable attached and you dont have dial tone at other end of cable the cable might be cut or shorted somewhere inbetween. You can test continuity by tying 2 wires together and test with a multimeter on resistance to see if it is open circuit or maybe even short circuit. To test for short circuit, untie the cables and you should not get a reading. If you do have dial tone when you plug in non-cordless phone the distance might be to far for receiver to pick it up(ie..greater than 10 metres). I hope this has been helpful.
Aug 26, 2011 | Panasonic Lands Phones
I have a panasonic pt-56dlx75. the lamps are okay i had them checked but my tv will not turn on, no blinking red lights just a green blinking light in the power button. I can also still hear a fan working...
I am not familiar with your TV but the blinking light is generally the error code! You will need to count the blinks, that will tell you what is wrong with your TV! Wish I could help you more!
Jan 07, 2011 | Panasonic PT-56DLX75 56" HDTV
Ineed to reset the lamp timer on my panasonic pt-56dlx75-k tv I installed a new lamp
terryc43,
This should solve your problem.
1. Turn on the television.
2. Press the down button on the TV Display (not the remote)
3. While pressing the volume button, press the "split" or "PIP" button on the remote.
This should reset your lamp timer.
Thanks for using FixYa and for the great rating!!
hardrocko
Oct 28, 2010 | Panasonic PT-56DLX75 56" HDTV
Where do I purchase and how do I replace a picture lamp for a panasonic PT-56DLX75 56 in. HDTV Television ? I live near Sioux Falls, South Dakota.
Hi there this online store has the lamp you need
http://www.discount-merchant.com/SearchResults.asp?Search=PT-56DLX75
this link has your TV manual and check page 67 it will show you were the lamp is located in your TV
http://service.us.panasonic.com/OPERMANPDF/PT56DLX25.PDF
this link shows you how to replace the lamp
http://www.fixyourdlp.com/guides/panasonic/TY-LA2005.php
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!!
Oct 11, 2010 | Panasonic PT-56DLX75 56" HDTV
PT-56DLX75 turns off red light flashes. Replaced
You need to first CK power supply board for Bad capacitors they will be vented,swollen or puffed up on top ,if you do not see any then try replacing Ballast Board it is what Powers Lamp. Call Encompas Parts Dustrubtion for Part numbers and Prices or Visit teir Website online!
Mar 24, 2010 | Panasonic PT-56DLX75 56" HDTV
Pansonic FLP menu option won't work
check the buttons or buttons that are not making good contact in the menu and see if they are not blocked
Sep 09, 2009 | Panasonic PT-56DLX75 56" HDTV
How do I rest the lamp times on my DLP TV Panasonic PT-56DLX75/PT
The reset procedure is usually documented in the owner's manual. But if you can not locate that, please update this with the model number of hte set and we'll get that info for you. Please note that the procedure is relatively simple, but dependent upon the model number.
Thanks,
Dan
Feb 05, 2009 | Panasonic Televison & Video
Panasonic PT-53WX42 53" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
