Question about Dryers
Neptune dryer , model number mde9700ayw, have replaced thermostat number 1,2 and 3. thermister also. heating element has continuity. motor runs and dryer still does not heat. spec sheet says membrane switch is open. what is this ??? could there be a computer board problem ?
    President:
  • 1,714 Answers
Have you tested the heating element itself? There is also a timer control, and a centrifugal motor contact in the element circuit. There is.
also a thermal fuse...
Posted on Jul 23, 2009
Dryer not heating
Hello there and welcome to fixya
Here are the most common things that will need to be checked with a meter to ensure there is continuity on these parts no continuity means that the part is bad and needs replacement ok?
Thermal Fuse
If the dryer doesn't heat, but the drum turns, check the thermal fuse(s). The thermal fuse protects the dryer from overheating and helps to prevent fires. If the thermal fuse is blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric solenoids which open the valve to let the gas flow into the burner assembly. If the dryer doesn't heat one or more of the solenoids may be defective. If the igniter glows for 90 seconds but the burner flame doesn't light, replace these coils as a set.
Dryer Igniter
If the dryer doesn't heat, the igniter might be burned out. Check the igniter for continuity with an ohm meter. Dryer igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can burn out over time. If the dryer doesn't heat, the element should be checked for continuity. The heating element cannot be repaired and must be replaced if defective.
Heating Element Assembly
The heating element assembly on an electric dryer can burn out over time. If the dryer doesn't heat, the element assembly should be checked for continuity. The heating element assembly cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the heat given off by the flame. If the dryer doesn't heat, the flame sensor might be defective. Check the flame sensor for continuity. This is not as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn't heat the high limit thermostat can be defective. It can be checked for continuity. If the thermostat is "open" the dryer doesn't heat.
Cycling Thermostat
The cycling thermostat regulates the temperature of the air in the dryer. If the dryer doesn't heat it may be caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at fault when the dryer doesn't heat. Check all of the other components in this troubleshooting guide before replacing the main control board. The main control board cannot be tested easily and must be replaced if it is defective.
Timer
The timer is normally not at fault if the dryer doesn't heat. In many situations where timers are replaced they end up being returned. Check all of the more common components in this troubleshooting guide before replacing the timer
Oct 14, 2013 | Amana Dryers
It is a model no mde9700ayw and it stops and gives the code hE
This error means there is an issue with with the heating portion of the dryer. Could be the thermistor, or the element, or the control board. You have to use a multimeter to troubleshoot the problem. You unplug the dryer, disconnect the element and use an ohmmeter to test the element for continuity.
The element should be between 10 and 50 ohms if it's good. The thermistor should be around 10,000 ohms at room temperature and if both check good, replace the control board.
Hope this helps.
Jul 20, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
How do you replace the heating element in a maytag neptune dryer model mde9700ayw
I am about to find out! But according to Tim Mereno, which by the way sells the part for 65. said it is not really to difficult! I will let you know.
Jun 07, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
I need to know how you would replace the heating element on dryer model Maytag MDE9700AYW.
First you take off the top panel two screws then four qr five screws to take off console then four screws top of front panel and two scews just below your filter on front panel and you have access to your element
Apr 29, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
THE DRYER IS NOT PUTTING ANY HEAT OUT.
ften a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Jan 22, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
Dryer runs hot and clothes come out badly wrinkled This Neptune dryer is about 7years old.
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the blower motor to make sure it is not faulty, also check the blower fan blade to make sure it is not broken or plugged with lint.
Check the Door Switch.
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape and running the dryer to check to see if the element is red or not,
or with an ohm meter check the two terminals of the thermostat/thermister
after you have removed the wires, the thermostat/thermistor should have/show continuity across the terminals.
If the coil heats up, or the thermostat/thermistor shows an open circut
then replace the thermostat/thermistor as it is defective.
If it overheats the dryer will not operate properly.
It's located on the blower housing.
It cannot be reset. A vent clogged with lint can cause it to overheat.
You can test it with an Ohm meter/continuity checker, if no continuity,
replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace an element go to the following website, it will give you an idea what you are in for:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Jan 16, 2011 | Maytag Neptune MDE5500AY Electric Dryer
I have a Maytag Neptune Dryer that won't heat. we replaced the thermistor and the control board. What else could it be?
First unplug dryer and test your heating element for continuity with a multimeter if it has more than about 30ohms it is bad.Next check for 220v-240v at the heating element with the dryer running (This is not a test for an amateur. If you are not familiar with electricity I would recommend calling a service tech. If you have 220v-240v there and no heat the heating element is most likely bad. If not then trace the wires back to find the open circuit could be a thermostat or the thermal fuse or just a loose wire/bad connection.
Oct 28, 2010 | Maytag MDE9700AYW Neptune 174 Electric...
T5 error code
e5 code have replaced thermister
Jul 24, 2010 | Maytag MDE9700AYW Neptune 174 Electric...
Maytag Dyer model # MDE9700AYW wont heat it blows cold air
Ohm out the thermal fuse, if it is ok, then you can ohm out the heating element, be sure to visually check the element as well becqause it could just be shorted out internally giving you a reading, but first and foremost check your voltages be sure you are getting 240 across the outer plug spades and 120 volts from left to common and right to common, unplug this thing before you get into the element area or you could end up with a smokin fro !
Apr 07, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Maytag dryer mde9700ayw
I have the same problem--it is the heating element. Bad news is they don't make the part anymore. The solution from maytag.com is to buy a new one and they will reimburse you 15%...not a very good solution considering how much this one cost and the amount of years it has been used.
If you find a place that sells the heating element please post!
Aug 31, 2008 | Maytag MDE9700AYW Neptune 174 Electric...
Dryers Logo
169 people viewed this question
Top Dryers Experts
