REMOTE SENSOR NOT WORKING - Televison & Video
  • 13,433 Answers
Have you checked that your remote is working? are the batteries in correctly? Are the batteries empty?
Posted on Jul 25, 2009
Emerson lc320emx remote sensor not working
Some advice--the sensor if bad requires the set to be opened and will be on a tiny board--whole board would have to be replaced as this company does not sell single parts (most now do not).
I would have the remote tested---most shops have a tester where remote is pointed at it---buttons (any or all) pressed to check it.
Some digital cameras when the remote is pointed at them will have a flash when the remote is used---
Either the remote or the sensor or something near the sensor is the problem.
If remote held very close to sensor and works----sensor is the problem most of the time.
Apr 16, 2012 | Emerson LC320EMX 32 in. LCD HDTV
Toshiba 43" 43H70 Projection TV - Remote Sensor not working
Here is your manual
Someone else with same problem
Seems like they you may have sensor problem, remove board and check solder connections and/or replace IR sensor bad pic below of toshiba sensor board below.
7151e29.jpg It should be hidden behind the smokey plastic cover in the right corner of set,
Dec 30, 2007 | Toshiba 43H70 43" Rear Projection...
TV does not detect remote control.
Remote control receiving sensor circuit problem in the TV. Mostly due to degradation of the sensor over a period of time.
Go close to the TV and see whether you get a response. If it responds try determining the distance back wards. If the remote works up to certain distance, the problem is weak sensor (TV).
If totally not operative it is sensor circuit problem. It could be sensor or it's associated parts.
May 24, 2010 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Remote sensor does not work. Have tried three different remotes
Your problem can be from any of these: Main Board, IR Sensor or Remote. Watch the youtube video attached to diagnose it correctly.
Feb 02, 2010 | Hyundai ImageQuest HQL320WR 32 in....
Sensor for remote is not working on the tv
Tries a little Alcahol with a Q tip clean the tv IR sensor,do the same to the remote and change batteries,tv sensor saldom broken,only remote all the time.Tries this Website 1-800-Remotes Factory Original for new remote get the exact or very close to the original.
Sep 30, 2009 | Televison & Video
Replacement Sony RM ED009 remote not working
Remote sensor on the tv may not be working. Try using a camera by aiming the remote IR sensor of the remote control at the camera lens then press and hole any button and check if you see a flicker of light. If you do, the remote control is transmitting, if not, the remote control is not working. This will tell you if the remote sensor on the tv is not getting the signal from the remote control
Aug 30, 2009 | Sony Televison & Video
Remote sensor in the TV
Remote sensor is locketed on pcb it an be replaced
May 11, 2009 | Televison & Video
Hi i have a eurovox max.i can turn the channels over on the box but not with the remote.i have tried 3 remotes with it but it still doesnt work.is it my remote or the box.
If you have tried 3 remotes most likely the problem will be with the remote sensor on the box. There is a common problem with the solder joints for the remote sensor u can test your remote sensor and box sensor with your phone camera if you press a button on the remote and move the camera over it u will see it lights up if it doesnt then remote sensor or box sensor not working. Repeat process for box sensor with camera. Sometimes you can just re-solder the sensor and it will work if not you will need another sensor. Good Luck.
Apr 06, 2009 | StarTech.com StarView SV211K 2-port KVM...
Remote sensor
Bad connects at sensor inside TV or bad sensor.......
Toshiba part # 23009490............T.
Sep 21, 2007 | Toshiba 36A60 36" TV
Televison & Video Logo
132 people viewed this question
Top Televison & Video Experts
