I have a xerox m24 and and I also have a computer that detects the faults that this photocopier has gives me the error 103-208 the PWS has the option to change the numbers of the counters that are 3 but it does not obey me if someone could tell me something I would appreciate it And if I had to change the plate gave me address, thank you very much.
SOURCE: NEED TO CHANGE THE TRANSFER BELT & CLEANER XEROX M24
Total Document Solutions 2515 N. Shiloh Drive Fayetteville AR Y (479) 575-0770
SOURCE: a code error 116-321 appears on my xerox m24,what
uff
desconecta el hd de 2.5 en la ess pwb y prueba...
SOURCE: 116-330 fault on Xerox Workcentre
Error 116-330 - HDD fault, it's unplugged or unresponsive.. Out the hard disk in and then do the GP3 Special Boot Mode HDD Initialization: simultaneously press and hold 4, the Stop and the Power Save buttons on the Control panel while switching on the Power switch. Hold them down until the second circle on the screen starts to blink. this will initialize the disk.
If you have the same problem then it wasn't the hard disk's fault to begin with, you have another problem: most likely the ESS PWB ( PL 13.1) is defective and will have to be replaced. For that you will have to call a repairman
