Question about KitchenAid K5SS Heavy Duty Commercial Stand Mixer
How do i lift head? I can lift bowl but don't now how to lift up head. I bought on ebay with no directions. I can't find any buttons or levers to lift.
  • 1,305 Answers
I am pretty sure that the model K5ss has a fixed head that cannot be tilted...
The bowl just moves up and down..
K
Posted on Jul 23, 2009
I have ordered 3 cooks professional stand mixers for myself, my daughter and daughter in law and none of us am remove the mixing bowl - can you help?
On the right hand side of the unit there is a lever..lift the lever upwards and tilt back the head.
Then hold the bowl with both hands and twist to the left to remove the bowl.
Hope this helps you.
Dec 17, 2016 | Food Mixers
My bowl lift lever on the hobart (bought off ebay) K5ss doesnt lock the bowl into place. What do I need to do to fix it, or at least figure out whats wrong if something needs to be replaced.
On a bowl lift mixer there is a small metal clip on the back of the bowl support arm, it works in conjunction with a small "NIB" on the back of the bowl, when you put the bowl on the support arm there are two pins that the bowl rests on, on each side of the support arm, you place the bowl on the pins then press down the rear of the bowl untill the nib locks into the clip, if the bowl is not locking in place then one of four things are wrong, one of the pins are not on the support arm, the NIB on the back of the bowl has come off (it is spot welded on) or the clip at the yolk of the support arm has worn down or broke in half and there would be no locking action without it. The pins or the clip are inexpensive if it is the Nib on the back of the bowl you will need a new bowl. Hope that helps if not pleases get back with us so we can FiXya.
Oct 14, 2014 | KitchenAid K5SS Heavy Duty Commercial...
The flat coated beater has worn off the coating why and how to fix it
Hi ARADAM, you don’t provide the model number or say if you have a ‘tilt-head’ or a ‘bowl-lift' mixer, which would helpful, but you can easily download a PDF version of your Owners Manual from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number and select a file listed under Owners Manuals and save that file to your PC. You’ll need to have Adobe Reader to be able to open it. Turn to Page 11 and you will find the instructions for adjusting the mixer head height. I have extracted the instructions below:
Beater to Bowl Clearance
Your mixer is adjusted at the factory so that the flat beater just clears the bottom of the bowl. If for any reason, the flat beater hits the bottom of the bowl or is too far away from the bowl, clearance.
Tilt-Head models
• Unplug mixer.
• Lift motor head.
• Turn screw (A) SLIGHTLY counter clockwise (left) to raise flat beater or clockwise (right) to lower flat beater.
• Make adjustment with flat beater, so it just clears surface of bowl.
If you over adjust the screw, the bowl lock lever may not lock into place.
Bowl-Lift models
• Unplug mixer.
• Place bowl lift handle in down position.
• Turn screw (B) SLIGHTLY counter clockwise (left) to raise flat beater and clockwise (right) to lower flat beater.
•Make adjustments with flat beater, so it just clears surface of bowl.
If you find the adjustment screw missing, you’ll need to replace it. But now you’ll need
I hope this helps! –Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Dec 22, 2009 | Food Mixers
I need to raise the head of the mixer. The wire whip is hitting hard the button
Hi LEDAVETTORI, you don’t provide the model number or say if you have a ‘tilt-head’ or a ‘bowl-lift' mixer, which would helpful, but you can easily download a PDF version of your Owners Manual from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Tilt-Head models
• Unplug mixer.
• Lift motor head.
Bowl-Lift models
• Unplug mixer.
• Turn screw (B) SLIGHTLY counter clockwise (left) to raise flat beater and clockwise (right) to lower flat beater. •Make adjustments with flat beater, so it just clears surface of bowl.
Dec 18, 2009 | Food Mixers
I need to lift the head a little. the wire whip
Hi LEDAVETORI, you don’t provide the model number or say if you have a ‘tilt-head’ or a ‘bowl-lift' mixer, which would helpful, but you can easily download a PDF version of your Owners Manual from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Tilt-Head models
• Unplug mixer.
• Lift motor head.
Bowl-Lift models
• Unplug mixer.
• Turn scre3e30899.jpgw (B) SLIGHTLY counter clockwise (left) to raise flat beater and clockwise (right) to lower flat beater.
Bowl too low
Hi, JAKELEGJEETE, You don’t say if you have a ‘tilt-head’ or a ‘bowl-lift' mixer, but you can easily download a PDF version of your Owners Manual from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number (in your case, use KSM5PS)and select the last file listed that appear under Owners Manuals: and save that file to your PC. You’ll need to have Adobe Reader to be able to open it. Turn to Page 11 and you will find the instructions for adjusting the Beater to Bowl Clearance. I have extracted the instructions below:
Tilt-Head models
• Unplug mixer.
• Lift motor head.
Bowl-Lift models
• Unplug mixer.
Dec 11, 2009 | Food Mixers
Can you lengthen the beater by loosing a screw?
Hi, KLOEHR, your beater will not lengthen by losing a screw. However, if you lost your Beater to Bowl Clearance adjustment screw, then it might appear that your beater had ‘grown’ because now the beater may be touching the bottom of your mixing bowl, where previously it had not. Simply said, the beater didn’t grow the mixer head drooped.
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number (in your case, use KSM5PS)and select the last file listed that appear under Owners Manuals: KSM5PSWW0.pdf (2930.74 KB) and save that file to your PC. You’ll need to have Adobe Reader to be able to open it. Turn to Page 11 and you will find the instructions for adjusting the mixer head height. I have extracted the instructions below:
Tilt-Head models
• Unplug mixer.
• Lift motor head.
Bowl-Lift models
• Unplug mixer.
Dec 10, 2009 | KitchenAid KSM5PS Heavy Duty Stand Mixer
The bowl fits too close to the mixing blade and has scraped some of the surface from the blade. I can not find the book
VLCMM: You don’t say if you have a ‘tilt-head’or a ‘bowl-lift' mixer, but you can easily download a PDF version of yourOwners Manual from the KA website (http://www.kitchenaid.com/flash.cmd?/#/page/home). Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number (in your case, use KSM90P)and select the last file listed that appear under Owners Manuals: KSM90PSWW0.pdf (2930.74 KB)and save that file to your PC. You’llneed to have Adobe Reader to be able to open it. Turn to Page 11 and you will find theinstructions for adjusting the mixer head height. I have extracted the instructions below:
Your mixer is adjusted at the factory so that the flat beaterjust clears the bottom of the bowl. If for any reason, the flat beater hits thebottom of the bowl or is too far away from the bowl, clearance
Tilt-Head models
• Unplug mixer.
• Lift motor head.
• Make adjustment with flat beater, so it just clears surface ofbowl.
If you over adjust the screw, the bowl lock lever may not lockinto place.
Bowl-Lift models
• Unplug mixer.
• Turn screw (B) SLIGHTLY counter clockwise (left) to raise flatbeater and clockwise (right) to lower flat beater.
•Make adjustments with flat beater, so it just clears surface ofbowl.
If this solution has helped you, please rate it, thanks!. hslincoln
Nov 25, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Beater rubs bottom of mixing bowl.
JOE:You don’t say if you have a ‘tilt-head’or a ‘bowl-lift' mixer, but you can easily download a PDF version of your Owners Manual from the KA website (http://www.kitchenaid.com/flash.cmd?/#/page/home).Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number (in your case, use KSM90P)and select the last file listed that appear under Owners Manuals:KSM90PSWW0.pdf (2930.74 KB)and save that file to your PC.You’ll need to have Adobe Reader to be able to open it. Turn to Page 11 and you will find the instructions for adjusting the mixer head height.I have extracted the instructions below:
Tilt-Head models
• Unplug mixer.
• Lift motor head.
Bowl-Lift models
• Unplug mixer.
If this solution has helped you, please rate it, thanks!.hslincoln
Nov 21, 2009 | KitchenAid Food Mixers
A 200 mixer. the bowl lifting lever hits the bowl and guard.
If it hits the bowl its been dumped on the side and bent it. I have done this on sight I get a mapp torch and use a pipe wrench large one and heat it up at the bend where it goes in side and bend it out. or you can buy a new one take the head off four bolts under head and one roll pin inside easy to see and replace arm. The bending is quick and cheap. it will work like new be sure and clean and luber slides wd where it goes in neck.
Dec 23, 2008 | Hobart A200 Stand Mixer
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Logo
132 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
