Computers & Internet Logo
s
suresh Posted on Feb 24, 2017
M2 1317 ho0w to slove - Computers & Internet
Ho0w do i log in facebook ?
Point your web browser at Welcome to Facebook Log In Sign Up or Learn More
If another account comes up, log out of it by clicking the down-pointing triangle in the upper-right then clicking "Log Out."
If you then still can't log in to your account, click the "Forgot your password?" link located just below the password box on the login page.
1helpful
Ho0w do i test the blower motor on my 2006 kia optima
put power and ground direct to it with the cars harness disconnected
I recently got my 75 tc 185 out of storage and it is set up. Pulled off head and penetrating oil goes by piston. Any ideas on ho0w to free it. Thanks Randy
Pour break fluid in there let it set awhile, poor more in there, it will eat all the corrosion or rust from the rings and piston walls. Eventually freeing it up, hope this helps you.
1helpful
2answers
Ho0w 2 edit my pic?.
use paint or photoshop cs4,you can edit your pic. there.
Not emptying, ho0w to get to the pump?
If nothing obvious like blocked / obstructed outlet pipe
You need to check if the outlet pump motor in line with the outlet hose is spinning when in the outlet mode. First check if it is spinning by looking at it and see if the small fan is spinning. If it is turnning this means that it has power and the internal "impeler" that pushes the water out has become loose. Remove the pump (easy job) and repair. If it does not spin you need to determine if the 2 push on terminals have power on. If there is voltage and the motor does nut spin this indicates that the pump motor is open circuit and must be replaced.
Mar 26, 2010 • Dishwashers
Grand Canyon Tech
Grand Canyon Tech
