Question about Dryers
Our Bosch Axxis 5401 has stopped drying...the cycle works fine, but it doesn't seem to be producing any heat. The heat transferer has been cleaned and the condensation hose has been checked and is all clear. I'm out of ideas...but any input is highly appreciated.
  • 98 Answers
Check heating element , if heating element is ok check the limit switch
Posted on Jul 23, 2009
Dryer doesn't power-on.
Simple answer: way too much dryer lint. Worth cleaning out.
Mar 04, 2018 | Bosch Axxis WTA 3510 Electric Dryer
Bosch axxis wtl 5410 dryer takes too long to dry.
You should have a cycling thermostat. this is most likely bad or your dryer vent may be clogged. Something is cutting the heat off before it gets hot enough. Both these cause this problem.
Nov 17, 2009 | Bosch Axxis WTL 5410 Electric Dryer
My Bosch Axxis electric dryer Mod. # WTA3510UC 82/IV takes a few cycles to dry if it dries completely. The laundry doesn't seem to get warm no matter the setting. Have checked exhaust, cleared lint from...
i would check the actual electrical connections, to both the unit, and the downline connections to that actual element itself, its unusual for an elemnt to only go a lilttle bit... it works or it doesn't...
since you seemed to be very knowlegable, ohm
out the element as well as your plug and outlet
ther emay be a loose connection somewhere
Oct 13, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Bosch Axxis Condensation dryer not working
Try to vacuum clean inside the door contact breaker (female part). If you can remove the dust it should start working again.
Jun 08, 2009 | Bosch Axxis WTL 5400 Dryer
Bosch Axxis WTL5410 condensation dryer does not heat up
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
May 03, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Bosch Axxis Starts and stops
The lint light keeps coming on and shuts the dryer off so clothes are not dry. I checked the filter and it is clear. Now the bottom of filter is cracked (plastic part) so I need to replace. But why does the lint light come on now after 5 years of use? It never came on before even when the lint filter was full?
Apr 20, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Bosch axxis 3510 dryer doesn't dry clothes
well first check the Thermal area inside the unit, if you have an idea doing this, it could possibly easily for you to do the work.. on the thermal area check for any burn fuse or any faulty parts relating or was connected on the thermal area.
Jun 26, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Bosch WTL 5400 running, but not heating
I've just fixed mine. The heating element at the rear under the covers was broken - crappy design BTW!
Mar 18, 2008 | Bosch Axxis WTL 5400 Dryer
Dryers Logo
85 people viewed this question
Top Dryers Experts
