I don't know how to access to clean out the drain. I just blow it out from the drain tube, but that doesn't last. I took the cover off, but that didn't provide the access to clean it out. The manual I have doesn't help.
Your drain tube is usally under the coila and is sort of hard to access it anyway. There are two things you need to do 1st take a wet/dry vac and hold the hose on the drain tube which will **** out any type of blockage there is (mostly algae) 2nd you need to get some treatment tabs from an a/c supply shop that all you do is place one of these tablets in the drain pan and it will prevent the buildup of algae therefore preventing your clogging issue. Good Luck
Dave
Was this helpful?
Yes
No
Popular Solutions for Fujitsu 18C1 Air Conditioner
The wall unit won't respond to the hand held timer/control. Worked fine a month ago. Batteries...
(More)
The wall unit won't respond to the hand held timer/control. Worked fine a month ago. Batteries seem OK in hand held unit.
Timer and operation light flash similtaniously 5 times then 5 second gap then flash again. continues...
(More)
Timer and operation light flash similtaniously 5 times then 5 second gap then flash again. continues when turned off by remote but no heat. Manual says "immediately stop operation and consult authorised service personnel". Did this, they unsure and say turn off at isolating switch for one and a half hours then try again. Third try this has worked but did it again and again two tries before starting, going okay presently. Any ideas what this code is advising?
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
