Question about Kenmore Elite 45986 Front Load Washer
Kenmore elite smart Wash quiet pak 9 with an f2 code
Sometimes I get this code, looking for the answer
I had the same or similar problem, after troubleshooting with the above post to no avail I started taking the maching apart.
Here is what fixed my F02 code:
1 Took off bottom plate below the door revealing the inside of the machine
2 Carefully unscrewed the plastic filter trap
3 It was stuffed with all sorts of junk so I emptied it
4 Replaced the Filter trap where it goes
5 Put the bottom plate back on below the front door
All along the filter that helps keep the drain lines from clogging was clogged itself, if you havent checked yours ever it might be a good idea to look inside.
Hope this helps someone
Posted on Aug 22, 2012
  • 2 more comments
  • gidzhome
    gidzhome Apr 09, 2013
    ABSOLUTELY !!!! Just as teh above guy said. DIdn't know there was a drain filter down there. Tw osocks got trapped. Works like a charm now. Whew !!!!!!!!!!!!
  • Veronica Blake Lovejoy
    Veronica Blake Lovejoy Mar 01, 2014
    fixed our problem. thanks
  • Candy Baker Burdine
    Candy Baker Burdine Jul 31, 2014
    Thank you SO MUCH...fixed my problem, too (other than the fact I didn't get the cover to the filter screwed back on tight enough - LOL - I oughta know better than to close it up before I run a cycle to check! Live and learn!).
  • travishill02 Sep 07, 2015
    To clean the plastic filter all you need to do is:
    1) Get a 7MM socket or appropriate male star screwdriver
    2) Remove the 3 screws that hold the bottom panel on the washer
    3)Place a towel under the washer and carefully unscrew the filter out of the assembly (about a half gallon or more of water will come out as you take the filter out)
    4)Remove all the debris from the catch basin in the filter
    5)Put filter back in and re-attach the panel to bottom of washer
    The whole process takes less than 10 minutes and is very easy to do. It had been a while since I cleaned mine out there were about a half dozen coins in it and some paperclips.
  • 5,911 Answers
"F02" is a Long Drain error code. This usually means the drain pump or drain lines are clogged, or you have a pump that is malfunctioning. Restarting the washer will not clear this code. The following link explains:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
If you need to replace the drain pump, they can be purchased on line at searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com, or repairclinic.com. You can use any web source you like, but these, I have found, offer the best service and pricing. Shop all of them for the best price. Just use your model number (located around the door opening) for your search criteria.
Hopefully you won't require any parts. If you have any questions, please let me know. I hope this helps you.
Posted on Jul 23, 2009
  • faby82
    faby82 Jun 03, 2012
    and whats means F20
Could some one show mw where the drain pump filter is.thanks
Posted on Sep 07, 2015
Kenmore elite smart wash quiet pak hf code
i think the hf means heater fault,,,,,,,,,,,,or the thermostat
Jan 27, 2015 | Kenmore Washing Machines
The kenmore elite smart wash quiet pak 9 I opened the door and threw something else in and now a light is on thar says controls locked and it wont do anything
There should be a button on the control panel that says "open door" you need to push that button and wait for the washer to shut off before you open the door. Try pushing that button to see if that resets. My guess is that you broke the safety latch when you opened the door and it will need repair.
Mar 10, 2014 | Kenmore Washing Machines
Kenmore Elite Smartheat Quiet Pak 9 won't start. Light turns on and off inside drum when door opens/closes, but no lights come on on the outside display.
My Kenmore Elite dryer keeps beeping..just going through the end of cycle alarm-high,low,off...anyone have any suggestions?
May 30, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore elite he4 quiet pak 9 dryer display code
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 15, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore elite smart Wash quiet pak 9 has got the control panel set to lock mode. How can we open it?
The LOC code merely means the control responded and locked the door. You'll find a tech sheet under the top panel of the machine to help guide you thru the diagnostic process, which is fairly involved.
LOC means it thinks the control panel is locked. This gives the ERR indication when you push the buttons. To unlock it you need to hold down the Options and Select buttons together until it reacts.
I know this may seem silly but - On the top right back corner of your washer hit it with medium force with your fist, this helps.
Jun 27, 2009 | Kenmore Elite 45986 Front Load Washer
F 2 error code
Hi KG Oliver,
This is a common complaint on the Whirlpool built Kenmore's. Please follow this link to my solution for it.
Thanks,
SG
Apr 05, 2009 | Kenmore Washing Machines
Kenmore Elite smart wash quiet pak 9 Front Load Washer
Our washer is flashing a F21 and it never finishes the load there is always water left.. what can we do to fix it?
Oct 16, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite gas dryer smart heat quiet pak 9 HE4
possible front control bd ..be sure there is 220 volts to rear connection first
Aug 03, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite 45986 Front Load Washer Logo
5,106 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
