Question about Brother MFC-5840CN All-In-One InkJet Printer
Online set up for Brother MFC-8660DN
I try to set up this machine used for online printer, when I install, i was told no machine found. but i did plug the machine into my router, and the light is flashing. what should I do?
  • 832 Answers
See brother faq:
Posted on Nov 20, 2007
Need to clear "drum at end" after installing new
Simply open the front cover.
Press the Options key on the control panel.
The display will show "REPLACE DRUM - 1.YES 2.NO".
Press 1 to reset the drum count.
Close the front cover.
This procedure wil work on the majority of the Brother MFC series of laser based Printer Scanner Fax Facsimile machines.
Good Luck and Thank You for using Fixya WheatlandServices
Nov 04, 2010 | Brother MFC-8660DN All-In-One Laser...
Click HERE to download the user's manual.Please refer the troubleshooting steps.
Click HERE to download setup guide.
Please don't forget to rate the solution.
Mar 28, 2008 | Brother MFC-8660DN 5-in-1 Laser...
Problems printing to Brother MFC 8660DN printer
Pull the paper tray, likley a small black lever to the left of the roller called the edge actuator is dislodged and hanging down. When in position the actuator should easily push up and appear flat next to the roller.
Dec 09, 2009 | Brother MFC-8660DN All-In-One Laser...
I have a Brother MFC-8660DN. When I receive a fax
That type of problem comes from either the drum or the fuser, the best way to check is to unplug the machine while it's printing and see of the shadow is on the paper before the fuser, if it is then you need a new drum, if not the fuser is the culprit.
Oct 28, 2009 | Brother MFC-8660DN 5-in-1 Laser...
How to change the fuser gear in Brother MFC 8660DN Printer
I recently changed the fuser gear on my MFC-8840DN (a similar machine) and type up detailed information. The pdf file of the instructions has been posted at:
Hope you find this helpful.
Sep 07, 2009 | Brother MFC-8860DN Printer
Black Vertical line on copies using MFC-8660DN
Vertical lines mean it is being caused by one of the rollers within the printer. This is usually either the toner cartridge or the fuser assembly. I would try changing out the toner cartridge first even if it is new as sometimes they are DOA and they are much cheaper than the fuser assemblies. If that doesn't work, probably the fuser assembly.
Jun 05, 2009 | Brother MFC-8860DN Printer
OCR problems for Brother MFC-8660DN with Vista 64bit
You are correct in that paperport 9 will not work on Vista and paperport 11 is the alternative. I called about a similar model and the guy at Brother told me that paperport 11 is included on an updated cd from for some models. It was only about $3 so you might want to check for your model. Hope this helps.
Apr 11, 2009 | Brother MFC-8660DN Network Mono Laser AIO...
Brother MFC-5840CN All-In-One InkJet Printer Logo
163 people viewed this question
James Cagle
James Cagle
Jim Keysor
