Dishwashers Logo
Linda Back Posted on Feb 24, 2017
I am in a rental and am not able to operate the Westinghouse 906 Dishwasher Model SB906B it either wont turn on or when it does stops with a flashing pre wash light.
5 Related Answers
Anonymous
  • Posted on Apr 12, 2008
SOURCE: Westinghouse 906
mine had a similar problem i got a 905 though and it was doing the same i pulled the front door apart to get to the switches and other electrical things and all i did there was a vacuum hose thing (black) i blew into it and re assembled to hole lot i think something might have been blocked in the hose or where ever it goes to and wallah it worked but make sure you turn off the power first
cheers viking63
Anonymous
  • Posted on Feb 22, 2009
SOURCE: westinghouse 906 leaks from front door
I’ve got the same make and model which had the same problem …if your sure its leaking from the door it will be coming through where the door jam or seal mounts and then leaking into the wall…..what you need to do is get yourself a tube of industrial silicon sealant and bead some silicon along between the back of plastic door seal mounts and the stainless steel wall lining...then allow silicon to set for 24 hours before running machine again
I believe over time the carcase and doors do warp causing these leaks
Hope this solves your problem
Anonymous
  • 109 Answers
  • Posted on Jun 16, 2009
SOURCE: SMEG dishwasher - cycle buttons
What is the model of the dishwasher? Open the door and look down the right hand side for a sticker and repost please. As a rule number 3 is a normal wash :D
Anonymous
  • Posted on Apr 06, 2010
SOURCE: dishwasher does not wash simply beeps continously
If your dishwasher is a whirlpool or IKEA then maybe the answer given by emmanuelr in "Whirlpool dishwasher ADP5962 F7 error code" may do the trick. It certainly worked for me. Bit technical but if you are happy taking the sidepanels off the thing then the fix may be easy.
Anonymous
  • Posted on Dec 13, 2010
SOURCE: Kenmore ultra wash dishwasher control lock light flashing
Just press the 'Air Dry' button for 5-6 seconds....I have an ancient Kenmore Dishwasher (ULTRA)
2helpful
I dont have the manuals to my philips universal remote so i need to add componts dvd
Try this link, http://www.universal-remote.net/philipsmagnavox.html
or instructions are as follows - Direct Philips Magnavox Universal Remote Code Entry PM335
1. Press and hold the Code Search button until the red
indicator stays on. Release the Code Search button.
2. Press and release the desired mode button (TV,
DVD, etc.).
The red indicator blinks, then stays lit.
3. Enter the 3 digit code from the code tables. Note:
after a valid code entry, the red indicator turns off.
For an invalid code, the red indicator flashes.
4. With your device on, press CHANNEL Up. If the
device responds, no further programming is
required. Note: If some buttons do not operate your
equipment, try one of the other codes for your
brand.
TV
MULTITECH ................... 906
MULTIVISION ................. 010
NAD ............ 002 120 502 512
NEC ............. 002 102 110 111 502 510 602 901
NIKEI ................................ 805
NIKKO ............... 002 407 502
NTC ................................... 407
ONKING ............................ 805
ONWA ........................ 805 906
OPTIMUS .................. 120 618
OPTONICA ............... 111 918
ORION ................ 105 115 713
PANASONIC ...... 007 107 516 608 618 718 807 901
PHILCO ...... 002 009 102 109 309 402 408 502 508 807 901 914
PHILIPS ..... 002 009 109 202 209 210 310 402 408 508 510 807 901 914 917
PILOT .............................. 002
PIONEER ...................002 120 502 519 610
PORTLAND.................002 102 407 502
PRECISION ....................... 218
PRICE CLUB .................... 112
PRISM ................................ 107
PROSCAN ......... 312 601 704 719
PROTON .................... 002 119 220 502 910
PULSAR ............................ 713
PULSER ............................. 002
QUASAR .... 007 107 516 608 618 718 807 901
RADIO SHACK/REALISTIC ......... 002 111 117 406 502 506 601 618 704 705 805 818 906 914
RCA ..... 002 011 102 211 302 312 318 320 406 409 411
420 502 511 514 519 601 702 711 719 809 811 901 909 911 912 914
RHAPSODY ..................... 003
RUNCO .............................. 713
SAMPO ....... 002 119 502 818
SAMSUNG .. 002 012 102 103 112 212 502 512 818 914
SAMSUX ........................... 502
SANSUI ....................... 115 215
SANYO ............002 412 506 619 902
SCOTCH ..................... 002 502
SCOTT ............... 002 004 105 206 502 805 906
SEARS ............... 002 112 206 312 502 506 512 520 601 612 619 704 719 902 914
SHARP 002 013 014 111 502 712 812 813 913 918
SHOGUN ........................... 002
SIGNATURE ...... 601 701 903
SIMPSON .......................... 402
SONIC ................................ 003
SONY .................. 202 708 801
SOUNDESIGN ... 002 206 402 502 805 906
SPECTRAVISION ............ 921
SQUAREVIEW ................. 520
SSS ....................... 002 805 906
STARLITE ........................ 906
SUPREMACY ................... 019
SUPREME ......................... 801
SYLVANIA . 002 009 109 209 309 402 408 502 508 717 807 914 917
SYMPHONIC..... 520 904 906
TANDY ............................. 918
TATUNG ........................... 901
TECHNICS ................. 007 107
TECHWOOD.............002 007 107 502
TEKNIKA .. 002 019 102 112 206 209 402 407 502 512 601 618 701 805 902 906
TELECAPTION .............. 313
TELERENT ............... 601 701
TERA .......................... 002 220
TMK ........................... 002 502
TOSHIBA ... 112 313 413 506 510 512 613 902
UNIVERSAL .............. 310 806
VICTOR ............................. 607
VIDTECH........... 002 102 502
VIKING .............................. 019
WARDS ....... 002 004 009 102 109 111 206 209 310
408 502 508 513 601 701 704 806 807 914
WHITE WESTINGHOUSE ... 311 611
YAMAHA... 002 102 502 914
YUPITERU....................... 805
ZENITH ............. 002 008 115 215 405 407 601 701 713 903 916
1helpful
Sounds like a tractor in the kitchen when the machine starts to wash dishes is a Westinghouse 906
This is yet another motor fault caused by defective components. Seeing a lot of these. Main motors carry "run capacitors" which are failing, so need replacement. A cheap part - but causing a lot of motor problems when they give up.
1helpful
I have a universal remote control which is philip and tv set which is also philip but I dont know the code to be used.
DVD, etc.).
brand.
TV
please do rate the solution positively.thanks
Stops mid cycle often
Hi there, did you ever find out what was wrong with your dishwasher? I have a Westinghouse 904 doing the same thing but when we moved into this house the manual was long lost. Any thoughts would be greatly appreciated.
My email address is [email protected]
3helpful
Dishwasher not emptying
either the pump is not working or the discharge hose is clogged, if you have an air gap on the sink take the hose off and hold it down see if the water comes out by tself if so the pump is bad if not the drain is colgged take out the bottom tray you will need a 1/4 inch nut driver take the plastic screen cover plate off clear it of debris, there is a sharp metal blade in there so be careful, after cleaning it out turn on to rinse and see if it drains if not you will need to either replace the dishwasher or the pump, dollar for dollar new dishwasher time
4helpful
Motor starts but no water entering dishwasher
TRy priming by putting a jug of water in bottom of inside of dishwasher
1helpful
No solution as yet, will most likely replace the dishwasher.
2answers
WESTINGHOUSE 906 DISHWASHER
Has anyone managed to find a Manual for the Westinghouse 906?
2helpful
3answers
Westinghouse 906
jules1676 The use and care manual for your dish washer you can download from the Frigidaire web site: http://www.frigidaire.com/support/ResultsPage.asp?strModel=mdp531rf&User= I'll be glad to help you with any further questions. Gendos post back...
2helpful
Powder not dispersing
possible the wash arms are not rotating - a common cause of powder not being taken. check by opening the door when in use and look to see if arms rotate. if not, then remove the arms and clear the jets especially the angled jets at the end which cause the arm to rotate
Top Westinghouse Dishwashers Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Westinghouse Dishwasher Expert? Answer questions, earn points and help others
