I have a old Matsonic Motherboard.
The board is MS7117C.
The bios calendar date says 05/19/2000
I have search several times for a valid update for this bios. I am currently running MS Windows XP Professional on it.
The problem is that it keeps locking up and sometimes does not boot up.
Please help me find the correct bios upgrade for this Matsonic MS7117C.
Bye the way, I already paid for the membership cost to Esupport.com and downloaded the new bios update.......nothing happened. No errors and no problems.........as well as no update.
Please email me directly at
rchang1967@cox.net
I am technically competent as I am Cisco certified.
Thank you for your time,
Richard
South Windsor, Connecticut
I would first check the capacitors on theboard around the processor. Older boards have a tendency to blow the caps. Check our web site at www.ccl-la.com/badcaps.htm for what to look for. If you find cab caps you can replace them if you really want to keep running the board. If you find bad caps and have questions just email me.
Buddy Corporate Computer Over 21 years of PC and printer support/repair
I have a promax x chip and i want to fit it to my 2008 citroen c5 1.6 diesel. I am not sure of the...
(More)
I have a promax x chip and i want to fit it to my 2008 citroen c5 1.6 diesel. I am not sure of the maf sensor and which wires to connect to. There is also a wire for the o2 sensor? Regards Terry
Hi, i would buy NBA 2k10 for PC I checked my laptop specs and it passes the system requirement but i...
(More)
Hi, i would buy NBA 2k10 for PC I checked my laptop specs and it passes the system requirement but i got a question: It says the Grpahics card for Nvidia needs to be 6600 or better and minimum memory of the grpahic card is 128mb, my graphic card is Nvidia 8200M G (Integrated) and graphic card memory is 128MB, so will my grpahic card work and will i be able to play NBA 2k10? some people say Nvidia 8200MG (Integrated) cant play some games, is NBA 2k10 one of them, and if i can play i shld put it in high,medium or low settings? Thanks
