Question about Grilling
On a sonoma sgr30lp do you have to dissemble the entire interior of the bbq to replace the burners ?
  • Anonymous Feb 27, 2017
    It still does not clear the rotisserie burner and it's attachment brackets on the back wall.
  • Grilling Master
  • 3,238 Answers
No take the bars off the top and the burner covers , the burners might be screwed in at the back , other wise they will lift out .
Posted on Feb 24, 2017
I have a propane leak behind the burner control knob on my Barbeques Galore Turbo STS. Suggestions?
More than likely you will have to replace the entire burner manifold. To purchase the part, first contact BBQ's Galore 800-752-3085, to see if they have it. Depending on the age of your grill will determine that. If they can't help you try Cla Grills & Service http://www.clagrills.com/parts/barbeques-galore/barbeques-galore-parts-home.htm
I hope this helps you and thanks for choosing FixYa.
Sep 19, 2011 | Barbeques Galore Turbo STS 4-Burner with...
How does one replace charmglow burner tubes on my
most of it yes to get too, the parts you wish to replace
Jun 14, 2010 | Brinkmann Charmglow 810-7400-S Propane...
Ignitor on gas BBQ no longer works. Replaced battery and cleaned out chamber (light rust). I've tried to remove the ingnition housing, but the entire front panel of the BBQ needs to be removed. Suggestions...
Check to see if the probe where it sparks to the burner inside the grill is clean and not shorted by grease or other gunk and the burner itself in this area is not too heavily rusted or corroded. If not, short of disassembling the whole grill and replacing the spark module, spend $2-3 and buy one of those pistol type grill lighters. The ignition systems on BBQ grills rarely seem to last long.
Feb 24, 2010 | Grilling
Need to find lpg jets for 6 burner aussie roaster bbq. (the australian barbeque company) Bbq roughly 6 years old.
BBQs Galore sell these in their DIY section (Aussie Roaster is no longer sold at BBQ Galore, but the burner component is a standard fit). If you have an Aussie Roaster remember there is a bobbypin on the underside of the burner locking the back end of the burner in place, a few smacks with a little hammer will push this out so the old burner can be pulled out and new burners can be put in place.
Oct 17, 2009 | Barbeques Galore Capt'n Cook 4-Burner (NG)...
Weber Silver BBQ has 3 burners only 1 has normal flame.
you may have to remove the burners and clean the inside of them. they could have insect webs inside preventing the flow of gas. hope this helps. also, try opening the tank really slowly.
Oct 12, 2009 | Weber Grilling
No gas getting to bbq
I switched to the new style 20# tank with the new turn-on knob.  I couldn't get enough gas pressure to the BBQ burners for all three burners to light or to keep a strong flame on even one burner.  The new style tanks have a safety valve on the inside of the tank that shuts the gas off if you turn the knob on too fast because the safety valve thinks there is leak.  Shut everything off and then try turning the knob on real slow, especially at first, before turning it all the way on.  If that doesn't work (it didn't for me), then replace the large plastic connection valve knob (female end) that attaches the regulator to the tank.  Mine was for the old style tank and was black (low pressure).  I went to a propane company and had them replace it with a green knob (higher pressure).  Took it home and WALA!  Everything works fine now.  But it was very frustrating trying to figure why I couldn't get any gas to the burners after buying a brand new tank.  I hope this helps solve your problems.
Sep 15, 2008 | BBQ Guys BBQ400C/G42 Grill
Need a Manual for Turbo STS Elite 4 burner BBQ - HELP!
if you havent already done it call bbq galore 214 696 0030
Sep 08, 2008 | Barbeques Galore Turbo Elite 4-Burner with...
Replacement of burners charmglow 810-6320B
The only way I was able to get the screws out was to use a 5/16" cobalt drill bit to drill through the center of each screw. Then, and only then, was the GrabIT screw extraction tool able to grip and remove each screw. Of course, I had to break off what was left of the burned out burners first to get easy access to the screws. To replace the burners, remove 3 screws (in an L shaped pattern) from the left side of the burner control panel. I did NOT have to remove the utility shelf to get to these screws. The control panel can then be moved forward about an inch, thereby enabling the new burner tubes to fit into their gas spouts. TIPS: It was easier for me to attach the back of the new burners before trying to attach the fronts. I used new 6-32 machine screws to attach them. You'll need to look from the bottom of the burner control panel when attaching the front of the new burners -- to see better.
Jul 13, 2008 | Brinkmann Charmglow Stainless Steel LP...
Grilling Logo
168 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
