Question about Kitchen Appliances - Others
Where is the orifice located on a deep fryer changing from natural gas to propane
    Scholar:
  • 81 Answers
Inside the gas valve itself & on each burner tube. The coversion kit should come with instructions. If it doesn't you will to call Robert-Shaw (99.9% of valves made) for them.
Posted on Jul 25, 2009
Instuctions on how to change a pitco fryer from nat gas to propane
Hi there!
You need to order a gas valve conversion kit (from nat to propane), propane pilot orifice and propane burner orifice,
Gas valve conversion kit consists of a replacement spring thicker than of natural gas valve spring, gas valve cap and a sticker.
Pilot orifice for propane has smaller bore than of natural.
Burner orifice for propane has also smaller bore than of natural burner orifice (one for each burner).
You will be able to find these parts on the list of Pitco Distributor when you visit http://www.pitco.com
Regards.
Jul 08, 2012 | Pitco Frialator E24 Deep Fryer
I have two pitco fryer natural gas that I like to convert to propane please help
Hi there!
You will be needing a gas valve conversion kit (nat to propane),
propane pilot orifice and burner orifice (depends on number of burners).
You will find these parts awhen you visit http://www.pitco.com
Regards.
Jul 04, 2012 | Kitchen Appliances - Others
I am trying to switch a natural gas deep fryer to propane and cannot fimd the correct part
Hi there.
You can visit http://www.imperialrange.com , you can verify there the correct parts list for the model of your fryer for the conversion from natural to propane and you will be able to search there the nearest authorized parts and service provider in your area.
You will be needing burner orifice for propane, pilot orifice for propane (if available, if not, the whole pilot assembly), Gas valve spring for propane (if available, if not, the whole gas valve for propane).
Regards.
Aug 03, 2011 | Imperial IFS40 Deep Fryer
I have a older 40,000 BTU 3 burner natural gas deep fryer. I would like to convert to propane gas. The orifice number is size 32. Do I need to get different orifices to convert? The serial number is...
Hi there.
Burner orifice size for propane gas is number 55. You have to replace all burner orifice with this size if you want to use the fryer with propane gas. Pilot burner orifice should be replaced with propane pilot orifice.The gas valve spring should also be replaced with propane spring kit. The difference between the two spring is the natural gas spring is lighter or thinner compare with the propane gas valve spring.
Regards.
Jul 13, 2011 | American Range AF40 Deep Fryer
I bought a dcs fryer at a restaurant auction. I had it installed in my restaurant, and when I got it going flames were shooting out of the back. I had it looked at, but because there is no serial number...
The difference between Natural Gas Set Up and Propane Gas Set Up on Fryers are as follows:
Natural gas burner orifice has larger bore (#52) than Propane Gas burner orifice (#55 or #56).
Gas Valve's spring kit for natural gas has less tension (thinner) than Propane.
You have to order burner orifice ( the quantity depends on the number of burners your fryer has), pilot orifice and Gas Valve Spring Kit for Propane Gas if your fryer is set for Natural Gas or vice versa.
Regards.
Jun 22, 2011 | DCS Kitchen Appliances - Others
I like to know how to change from natural gas to propipe
You must buy first the appropriate conversion kit for your fryer, you can check and order only with the authorized parts dealer. Conversion kit consists of burner and pilot orifice and gas valve spring and stickers (propane) and installation manual. Propane orifice has smaller bore than natural and gas valve spring is for propane is thicker than natural gas valve spring.
Jun 03, 2011 | Welbilt Kitchen Appliances - Others
I JUST BROUGHT THIS IMPERIAL DEEP FRYER AND I WANT TO CHANGE FROM NATURAL GAS TO PROPANE GAS.
You will need a conversion kit from natural gas, most of this kit contains gas valve spring, burner and pilot orifice. Check the nearest authorized dealer in your area and ask buy the appropriate conversion for your fryer.
May 28, 2011 | Imperial IFS40 Deep Fryer
I got a dean that that is for natural gas and now I need to use propane...does it have to be re jeted or can I adjust the regulator or something
It will be safe if you use a Conversion kit from natural gas to propane. The kit consists or burner and pilot orifice which has smaller holes compared to the natural gas orifice, gas valve spring which is thicker than the natural gas spring, and ann instruction manual. You can visit the frymaster website and ask the local dealer on your country for the conversion kit.
Apr 11, 2011 | Frymaster Dean GF14-SD Deep Fryer
I have a small counter top fryer set up for lp gas how do i change to nat
check the supplier for the conversion kit.the kit contains burner orifice, pilot orifice and gas valve spring which are commonly needed for conversion from propane to natural gas or from natural gas to propane.
****natural gas orifice has larger bore than propane, gas valve spring for propane is thicker than for natural gas.
Mar 29, 2011 | Cecilware FMS-40 Deep Fryer
Change from natural gas to propane
1.You will need to change the pilot orifice and the burner orifices
2. You may need to change the gas control valve. Some gas control valves are made for natural gas and some are made for LP. They have regulators built-in, that deliver the correct pressure respectively. Natural gas is 3.5 inches of water column, LP is 10 inches of water column.
Some manufacturers sell kits to change the spring in the regulator from Nat to LP
You would need a parts breakdown on the specific model number of your fryer to find the parts you need. Hope this helps.
Apr 07, 2009 | Imperial IFS40 Deep Fryer
Kitchen Appliances - Others Logo
85 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
