Watches Logo
c
carol munger Posted on Feb 23, 2017
How can I verify serial numer of this watch - Watches
Can a serial number on a Gucci watch be checked for authentication?
Hello, I've just read here: http://www.ask.com/beauty-fashion/check-gucci-serial-numbers-a0287af75d5c1830#full-answer
that Gucci's Customer Service should be able to verify the serial number. The main customer service number is: 1 (877) 482-2430
3answers
How can i watch malayalam serials on online
Utube has numerous Malayalam serials, you need to go to google, type ' utube followed by the name of the serial..
Feb 20, 2015 • Watches
Gucci watch serial number check
Hello, Gucci will be able to verify the serial number on their customer service line: 1 (877) 482-2430
1helpful
2answers
I want to buy a Cartier lighter but I want to make sure it,s real. How do I look up the serial number?
To look up the steel ligter serial number is very easy ,I specialize in buying and selling Cartier watches. I've seen fakes with all the correct marks and a serial number, but that doesn't mean they are legitimate. If the watch was registered by Cartier when it was sold or if it has been sent in to Cartier for service Cartier will be able to verify it is authentic, but be aware that if the watch was not originally sold in North America or was not registered when sold (fairly common) it can still be authentic. Some sellers offer the Cartier quartz model for sale and only state that the watch has a quartz movement, but fail to mention if it has a Cartier quartz movement. If it has a replacement movement in it the watch is technically authentic, but not original and is not worth as much as one with an original or a genuine Cartier replacement movement. The biggest mistake I've seen amateur Cartier buyers make is using the Cartier micro-script signature on the Roman numeral to verify authenticity. Indeed this is a good indicator, but not the best indicator as there were many Cartier watches produced prior to the technology required to make the micro-script possible and not all Cartier watches have Roman numerals for the dial to have the micro-script signature. Furthermore, the micro-script is not always located at the same place and if the dial has been refinished it may not appear at all. Another common problem is actually caused by language differences, i.e. "all original versus "authentic". A watch can be authentic without being all original. Unless someone has owned the watch since it was new and it has never left their sight it is impossible for them to state the watch is "all original" as a part could have been replaced at some point in time -- even without their knowledge. Your best bet is to buy from a reputable seller even if you have to pay slightly more money. -- Cartier_Specialist
May 08, 2012 • Watches
How can i check the serial number on verify there authenticy?
mcdevito75 here, The serial number is the number off the movement itself. You"ll have to remove the back cover of the watch or have a watch repair shop remove the back cover and record this and all info on the watches movement. Any info on the back cover of any watch can help somewhat but you need the info off the movement itself for accurate info regarding any watch.
Oct 23, 2010 • Watches
Antique pocket watch
Case info does not help in dating a watch, A movement serial number helps greatly.
r/
David
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
