Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Spin Problems I have a Whirlpool LSQ9660PW0 that the high speed spin stopped working on it drains fine and spins but it remains at the same speed through entire spin cycle. The motor has four sets of windings so I am wondering if it would be more likely the motor or the timer? Thanks for any help.
  • 213 Answers
Check all the wire conections at the motor. there may just be a wire loose. if not, replace the motor
Posted on Nov 20, 2007
Whirlpool Cabrio Washer does not spin the water completly out of the clothes
probably not getting into high speed spin mode
they spin slow in the initial stages to allow the clothes to become evenly distributed then after the water is removed they pick up speed
It is possible a problem in the program board not advancing to high speed
Call in a technician for a proper diagnosis and a quote
Jul 07, 2016 | Whirlpool Washing Machines
What will cause the high spin not to ingage? The lwo spin works fine.
Hi.
Principally the following:
Door lock (there is a double check on lid switch before spin)
Drain problem (Machine must end drain before spin-check blockage, rear hose, drain filter at the bottom)
Pressure switch (it determines when to end drain and start final spin).
Here a page about drain and spin problems.
If you need parts or schematics see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 20, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
I have an Estae(whirlpool) washer that i have had for 9 yrs. It works fine until it get to the spin cycle. Then it stops and the water stays in the washer and will not drain. Every different wash mode...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Dec 12, 2010 | Washing Machines
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
Jun 05, 2010 | Whirlpool LSB6200KQ Top Load Washer
My washer spins but doesnt spin on the final spin and leaves the clothes all soaked. it stops at 6 minutes on the final spin
is the machine draining correctly?
the machine will oftin stop if not doing so.
you can try cleaning out the coin trap/drain pump hose.
Jan 12, 2010 | Frigidaire Affinity ATF7000E Front Load...
Kenmore mod. #417.44092500 high speed spin doesn't
replace speed control board located right rear base of unit
Sep 12, 2009 | Kenmore Washing Machines
Control lock light will not go off.
Do you have any error codes?
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Control Lock
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
61 people viewed this question
Dan Webster
Dan Webster
Sal De
