Question about Danby DPAC8020 Air Conditioner
Unit blows only hot air after a few minutes. shuts off and on repeatly and seems to overheat.
  • 22 Answers
Check the out flow tubing, Make sure that nothing is stopping it up and that it is as straight as possible. Hope this helps 2rns4u <*{{{>(
Posted on Jul 23, 2009
Air conditioner damper
Could be a blend door problem under the dash.
Jun 17, 2013 | 1998 Jeep Grand Cherokee
2009 Nissan Altima A/C blowing cold for 20 min. then blows hot
if the ac system is very strong and there a lot moisture in the air the a'c evaporator core will freeze up and stop air flow threw the cold core only use the recuiculation part to cool the car down about 5-10 min the turn the recuit off
Aug 22, 2012 | 2009 Nissan Altima
Why would my heater blow out cool air when sitting still and then hot air when going down the road and then it's not all that hot
Try flushing or blowing high pressure air through the heater core lines. its sludge build up and need to be flushed through heater core only. check antifreeze fluid level. only put in straight antifreeze, do not mix. most people do not know what mixture should be, so be safe and add straight, it will not hurt it, i run 100% straight antifreeze and never had a problem or worry about it ever freezing and cracking my block, heads or radiator cracking.
Jan 29, 2012 | 2001 Daewoo Nubira
My 2004 PT Cruiser overheats whenever I idle for too long and when my air conditioning is running and the car isn't above 2000 rpms I don't know what the problem is?
Hi Laura.It would seem that the electric cooling fan is not cutting in when it is meant to. Check the cooling fan fuses first, (there should be two, one for the engine and another for the AC) Take the vehicle for an inspection and a scan, asking the mechanic to take special note of the fans and sender units which control the operation. Regards John
Nov 16, 2011 | 2004 Chrysler PT Cruiser
Amcor 10,000BTU set at 64 degrees - - temperature of air coming out of unit is 72 degrees. In one and half hour set at 64 degrees the room temp only went from 90 degrees to 84 degrees. Recommendations?...
I am not sure, i have a similiar unit that is brand new, seems like a faulty mechanism from the maker, it starts cold for about 2-3 minutes and then shuts down condenser and blows hot air repeating this cycle. I don't believe it ias a recharge, just a faulty machine
Jul 15, 2010 | Amcor PLM-14000E Portable Air Conditioner
The unit runs fine, but the compressor kicks on for 2 seconds and then shuts off, this just repeats over and over every minute or so. so it never blows cold air.
It could be a capacitor problem; however, more often than not, the compressor will fail to start at all with a failed capacitor. The sytem could be low on refrigerant causing the compressor to overheat and shut down. Another item to check before hiring a tech is to inspect all of your electrical connections and repair/tighten if necessary. Loose connections can cause motors to overheat and shut down.
Because you state "the unit runs fine" I'm assuming the fans are blowing air normally across the evaporator (blowing inside the RV) and normally across the condensor coil (blowing outside). Is this correct? If so, because the refrigerant level will need checked, you will need to have a licensed service tech look at your unit and offer his/her expert opinion of what your best options are.
Without having a toolbox in hand and being onsite to repair your system, I do hope you find this information very helpful to you in items to check yourself. Let me know if you have any further questions. :-)
Mar 13, 2010 | Dometic Rooftop RV Air Conditioner
My 2004 Lincoln LS first quit blowing cool air, it only blows hot air full blast on auto. Then the check parking brake started coming on sometimes, but resets when the car is turned off. Now, it...
DOES THE ENGINE OVERHEAT WHILE DRIVING? IS THE COOLANT CLEAN AND THE SYSTEM FULL? NEED TO KNOW THESE THINGS TO GIVE U AN INTELLIGENT ANSWER.
Mar 09, 2010 | 2004 Lincoln LS
I have a Mach III. Unit blows hot air and bogs down when cooling.
probably (90 %) the compressor's bad, depnding on the repair cost you probbly want to just get another AC unit
Aug 30, 2009 | Coleman Mach III Air Conditioner
LG 8008R compressor runs one minute then fan blows 3 minutes
You need to have an AC tech come out and do some preliminary testing on this.
May 12, 2017 | LG Heat cool Window Air Conditioner
Furnace is blowing but gas is going off and on all the time
Check the heat anticipator on the stat if its a manual one
Mar 16, 2009 | Heating & Cooling
Danby DPAC8020 Air Conditioner Logo
116 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
