SOURCE: Asko washing machine door not closing
Changing the door lock is one of the easiest things to do in a washing machine. Just note which wires go where & get a new door switch.
SOURCE: quad cab rear door closed and wont open
what you have to do is make sure door lock is in unlocked position put a flash light inside the door to see you need to get a screwdriver into the release spring area try to pry up on the hook area that flips over the piece thats mounted to the door jam it should release sounds like you need to spray wd or blaster in the lock assembly return spring not kicking back
SOURCE: Hotpoint Aquarius WF440 Washing m/c - Door Lock light
You have probably knocked of the connector or the catch (and on these it is very fragile as I have changed the catch 3 times on mine) is broken
SOURCE: door locked light flashing when door is closed
push on the door where the lock is... it may not be fully locked.
SOURCE: Washing machine doors
Electrolux has a reversible door for both front load washer and dryer. Just found that out at HHGregg because we need to put our washer to the right of the dryer, and none of the other makes will allow the washer door swing to be switched.
Open the front door and load the clothing into the washing machine. Check the owner's manual for the maximum load size. Overloading the washing machine may interfere with its ability to spin the clothes and rinse them clean.
