Question about Compaq Presario M2000 Notebook
Power light comes on will not boot up.
Please would you help me. My friend has a compaq presario M2000 PC notebook which is 2 years old. It has not had much use and never been misused. It was on a table working successfully. Switched off. Switched on again some time later. The power button illuminated the caps and number lock lights flashed on as usual and the fan switched on momentarily and then went off. No noises were made. The screen remained black. This fault is repeated at every attempt to boot up. Nothing is plugged into the computer. The fault occurs whether the battery is used or removed and the power pack is used. Removing and reinserting the RAM has made no difference. We have downloaded the service manual from HP and have completely exposed the mother board so feel ready to fix the problem if we only knew what it was. Could any one help us please Many thanks Juliet.
  • 6 more comments
  • undeterable Nov 25, 2007
    Thank you Tom! We have tested the power pack with the volt meter. The output stated on the pack is 18.5V. The meter reads 18.74 V. We are assuming that the battery charges because the charging light comes on when the Ac adapter is plugged in and is extinguished after the usual time taken for it to charge. We are really grateful for your advice. If you have any other suggestions we remain undeterred and keen to try them.
  • undeterable Nov 27, 2007
    Hi Tom.Thanks for your help. I would have to buy a battery connector board so I wanted to check with you first. We have tried with no battery in at all and there is exactly the same fault. Does this shed any more light?
  • undeterable Nov 29, 2007
    Yes Tom, I definitely will. I am awaiting text from parts supplier re the availability of the battery connector board. May I just check with you that the notebook would behave the same even if the battery and AV adapter are not plugged in? Thanks for all your help so far. I am away for 5 days will contact you as soon as I have installed the board.
  • undeterable Dec 05, 2007
    Hi Tom. I think that I must have mislead you with my description. I forgot to mention that the power button stays illuminated after the fan and caps and number lights have gone off. The power button stays on until it is held down for 5 seconds at which point it goes off. We have tested the battery connector board with a circuit tester and it is working fine. Sorry about the confusion. Do you have any further suggestions we could try?
  • undeterable Dec 06, 2007
    Thanks Tom, We will put computer back together this WE. Am slightly concerned as the display is black ie completely and utterly unilluminated, not just dim. Will get back to you when we have checked your proposition. Please don't give up on us.
  • undeterable Dec 07, 2007
    Tom may I just say that I don't think it is a screen problem because we did try the first half of the procedure you suggested before we asked your advice and it did not help. Also we think that the fan would continue to run if it were a screen malfunction. Please remember that the fan only comes on for a few seconds then goes off leaving the power button illuminated +/- the charging button on the front depending on whether the AC adapter is charging the battery or not. Thanks for your advice.
  • undeterable Dec 09, 2007
    Thanks Tom. I am unclear what you mean by a power issue. The power button which remains illuminated till it is switched off, is connected to the motherboard by a ribbon which is situated beyond the battery connector board and the external DC input. Does this make it any clearer? Thanks for your advice.
  • ten10 Jan 04, 2008
    power light flashes but will not stay constantly on when I try to turn the laptop on either when it is plugged into the mains,with or without the battery in place
It stll could be a moniter issue since the computer is not running any programs it is not heating up therefor it dosnt require a fan my compaq m2000 is doing the same thing try plugging your computer in to a desktop moniter and see what happens you might find that it still works,if you have tried that allready then sorry thats all i have. thanks
Posted on Jun 03, 2008
  • 1,601 Answers
Check the power pack tip for voltage (19v).
Power pack could of gone and battery drained.
Posted on Nov 24, 2007
  • 5 more comments
  • Thomas Christopher
    Thomas Christopher Nov 25, 2007
    The first thing to change out would be the battery connector board.
    Thomas Christopher Nov 28, 2007
    Sounds the same to me. The board switches between the battery and outside power.
    If this doesnt work I would be really suprised.
    Thomas Christopher Nov 29, 2007
    if this works for you, please rerate this.
    Thomas Christopher Dec 06, 2007
    I wont. Thanks for the update!!
    Thomas Christopher Dec 07, 2007
    you are right in thinking that the fan would continue to run if it were a screen malfunction.
    It seems that a power issue is the reason for your laptop trouble.
    Thomas Christopher Dec 09, 2007
    underable,By power issue I mean that the battery or AC power is not reaching the board, probably meaning that the battery board is bad. Did you change it out yet?
I have a compaq Presario cq40-215wm wil not boot screen stays black. light by caps lock and num lock blink 1 time over and over. Got the same result with a hard boot
Have you tried removing the battery, and disconnecting the power adapter. If you have not tried that please try that.
1. Once you have removed both. 2. Power up computer with just power adapter connected and no battery. 3. If the computer powers up shut computer back down 4. Put battery back in and leave power connected
If that does not fix the issue. The back light has possibly gone out on the computer. Depending on how old the computer is. 1. Either contact the manufacturer of the computer 2. Take computer to a repair shop 3. Consider purchasing a new computer
May 31, 2011 | Compaq Presario M2000 Notebook
Hi.. I have a Compaq Presario M2000. How do I turn on the wireless. Or does it even have that. It has a wireless symbol but it's not lit up. Thanks..
Yes, it has wireless and blue tooth. Simply download the owner manual of their website. Here is a link
Apr 26, 2010 | Compaq Presario M2000 Notebook
Update bios on compaq presario m2000?
There are usually two ways with Compaq's
One is with a DOS boot floppy
The other is via a windows utility
both are usually available from the support section on the Compaq website.
Heads up only do this on mains power not battery !
DON'T stop it or switch off for ANY reason
If you knew how many crashed bios questions come through Fixya.
Check the text file or only as to what problems that bios fixes and if they don't apply to you then don't do it.
Most bios updates fix very minor issues nowadays
Sep 09, 2009 | Compaq Presario M2000 Notebook
Compaq M2000 boot
check your memory card(s) you may have a bad on or two, and if that doesn't work then sounds like the mother board has become defective and needs replacing, but the ram Memory would be the cheeper fix first.
Jun 22, 2009 | Compaq Presario M2000 Notebook
Compaq presario m2000 imediately shuts down after
Check for blocked air passages - vacuum out the fan ports. (Don't use canned air - you'll just blow the dust inside, where it will act as an insulator and help things overheat.) Make sure the fans are actually turning. If there's any mold growing inside, that could cause the problem too.And for more contact
Jun 18, 2009 | Compaq Presario M2000 Notebook
Laptop will not start (compaq presario m2000)
Try removing the battery (which may be bad) and only have ac power connected.
Nov 17, 2008 | Compaq Presario M2000 Notebook
Compaq presario m2000 sound card
logon to compaq website search for your model and download sound drivers
Jul 15, 2008 | Compaq Presario M2000 Notebook
Computer wont come on
well, sounds like your power cord took a dump on you check and make sure power cord light is working first i would suggest
takeing up to office depo or computer store or maybe some one you has a lap like your try the power cord on it and see if it boots up that computer or takea differnt power cord and try reboot it they sale altn. power cords for laptops (cheaper in ebay ,ubid or just type in power cords in your search engine ). i hope this helps lala linda
Jun 03, 2008 | Compaq Presario M2000 Notebook
Audio drivers
hi Mike........
I download version XP and installer but I can't install
I don't understand.
Mar 22, 2008 | Compaq Presario M2000 Notebook
Help needed
try going to the manufacturer of your audio/net/graphic cards website and downloading updates.
Jan 17, 2008 | Compaq Presario M2000 Notebook
Compaq Presario M2000 Notebook Logo
399 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
