SOURCE: quad cab rear door closed and wont open
what you have to do is make sure door lock is in unlocked position put a flash light inside the door to see you need to get a screwdriver into the release spring area try to pry up on the hook area that flips over the piece thats mounted to the door jam it should release sounds like you need to spray wd or blaster in the lock assembly return spring not kicking back
SOURCE: Power sliding door won't close properly on 2005 Freestar
U will need to buy a can of spray white grease and clean and then lubricate all the tracks the door channels on as well as all the latches for the door, this will cure the issue in most cases, did allot of these while working at a Ford dealer.
SOURCE: Whirlpool Refrigerator Door Seal surface is HOT.
If the air flow on the condenser under the fridge is too low, the hot gas won't be cooled enough before it goes to the door jamb to stop condensation. Remove the plastic cover under the doors and look at the condenser (tube/wire thing underneath). If it is clogged with fluff, get a vacuum and nozzle and give it a good clean so the air can pass through. Other than that, your condenser fan may have stopped.
SOURCE: Reg door will not close
There is a flap inside the printer that guides the paper as it travels thru the printer. The flap has to be in a completely up position before the door can be closed. Problem is if you put the flap in the up position and then try to close the door the flap falls back down and blocks the door. You need to push the flap up and close the door quickly before it has time to fall back down.
SOURCE: back door on drivers side locked wont open or
can you lift the lock knob up at all?? If you can lift it and the door stays locked, the linkage inside the door is broken.. if you can't lift it up, then the linkage is most likely seized... you'll need to remove the door panel to actually see it
