Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
The Mr. Slim is leaking water. It is 103 out.
    Problem Solver:
  • 6 Answers
Is there water coming from the drain line outside? If not take a garden hose and back flush the drain line there may be some sludge in the line. DO NOT FLOOD YOUR HOUSE short quick burst's
Posted on Jul 26, 2009
    Problem Solver:
  • 19 Answers
If your unit has a pump to push out the water make sure the pump is working, plugged in and again that the water is getting outside. A bad pump is an easy fix. Also make sure the line going out is not damaged (kinked) on its way outside.
Posted on Jul 29, 2009
How does one access the drain pan in a Mr. Slim? I think I have stagnant water (minimally), mildew or mold somewhere and nee to make sure.
POUR some strong bleach water in it where you saw the second guy put water in . that should kill any bacteria if there is any
Aug 06, 2015 | Mitsubishi 9000 Btu Mr.slim Ductless Mini...
Leaking water
sounds like the drain is blocked or possibly the drip tray has a crack in it
Aug 01, 2013 | Mitsubishi MSZ-FE12NA MUZFE12NA Mr Slim...
Water dripping out of Mr. Slim on indoor unit.
Reason for water leaking.
1. Filter block. 2. Cooling coil block. 3. Alignment of indoor a/c unit is sloping downwards. 4. Drain pan block. It's advisable to service your unit first.
Jul 02, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Hi I have a Mr Slim Mitsubishi Aircon. I am not
my dear i am so so sorry but that oily liquid is freon an that will take a tech to come an find the leak an repair problem i wish i could coach you though to fix problem but i know you dont have the tools to fix it so hope i completed your question
May 19, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Just blows "coolish" air
Could be a dirty filter, or the coils need cleaning, or a refrigerant leak and it's not fully charged.
Aug 21, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Mr.Slim keeps freezing up
Hi my is Paul. it could be a number reasons but i would check to make sure the filters are clean and coil is clean. that thing that looks like a radiator. should be one facing inside the house and anther outside, clean them be careful not to been the fins. Or it could be low on Freon.
Jul 18, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Mr Slim unit "spits" water/dust mixture
some of those units are equipped with a condensat pump you could have a loose connection or a small crack in the line
Jul 08, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Water leaking at front of condensor ( inside)unit.
sounds like there might be a blockage in the condensate pan that is not letting all the water drain through the condensate line. if you can access this area try to clean all the debris out
Jun 12, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi Mr. Slim Mini Split MS-A12WA Indoor Unit
no sir gary,
the water would not go to the drain pan if you install it vertically.
water would just drop anywhere and would ruin a lot of things...
tnx 4 using fixya,
drcool
Sep 13, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi mr. slim is leaking water
you dont have enough fall creating a water trap which breeds bacteria into a green slim ball blocking drain you need to chop more brick wood what ever the pipe drain go through so there is very good fall problem solved the pipe being blocked causes water to back up these heads can loose 4 ltrs an hr in qld not sure on other state hope i was some help
regards john
john@topnotchelectrics.com.au
Jun 08, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
1,014 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
