Question about Navigon 2100 Portable GPS Receiver
GPS does not respond seems blocked .Tried memory car in another GPS and when it was put back it did not worked properly. The other GPS was not the same brand.
    Problem Solver:
  • 4 Answers
Try pulling the plug out as this may reset the unit.
Posted on Jul 23, 2009
When u turn it on all it does is show the memory card beening removed and then croses it out
This is because the memory card was not formatted correctly ir is missing vital files.
If you backed up your gps then you could reformat the card properly (not ntfs) and then restore to it which would get you back up and running.
If you need it in a hurry then switch it off remove the sd card and re-boot. this should put you back on the factory defaults unless you made any changes prior to putting a card in.
For formatting advice see here or here
If this information was useful please click
Aug 17, 2009 | Tomtom GO 730 Car GPS Receiver
My GPS is missing most maps & I cannot seem to transfer from cd
the maps are on the 1gb sd card in the side of your c220 unit.
If it's missing, get a 1gb sd card and find a computer that will accept sd cards and your cd that came with your gps, then download the maps from the cd to the sd card.
Your c220 only has 4 states on the unit itself.
The c230 has all the maps on the unit but only 1 million POIs versus 3 1/2 million on the c220
Mar 12, 2009 | Mitac DigiWalker C230 GPS Receiver
Tom Tom 500 says memory card not installed
What I can suggest is download the drivers & software first .. Than buy another brand of memory card.. I had same issue with a Mp3 player that I had purchased.. It wouldnt recognise the card even though it was setup properly.. I returned it and baught a different brand.. Worked Like a Charm..
#2 If you for some reason cant get the software to install or work properly, I suggest you buy a new Tom Tom (( EXACT MODEL )) and than take the old Tom Tom put it in the new box and take it back with your receipt and tell them this doesnt work.. Ive done that b4 with a Speaker system and it wasnt an issue with the store...
Good Luck !
Feb 24, 2009 | Tomtom GO 700 GPS Receiver
On a trip ,reached destination turned off gps will not come on. plug it in light comes on but screen is dark held on switch for one min will not respond tryed for last 3hrs no response
Take out the memory card and then reset the tom tom (with a pencil or something sharp), and then put the memory card back in and push the on button. let it charge up for as long as you can.
good luck
chris
Dec 14, 2008 | Tomtom Go Plus GPS Receiver
Navsgo go730 7" inch gps is not reading my memory cards anymore
yes,
first do a backup of ure maps, then format the card , try all the possibilities , fat , fat32 , one of the must work , then after formating , put the maps back on the card , and the gps will read the card
Nov 30, 2008 | Tomtom ONE GPS Receiver
Problems Dealing With the Controllers and Memory Card Unit
corey chan on your xbox 360 there is a reconetion buton. its the one that has the 3 arrows going to the right press that and the reconection button on the controler then it will work
Oct 21, 2008 | Microsoft Xbox 360 Console
My Tom Tom memory card doesn't respond when I insert it into device.
I red cross usually indicates an SD card problem.
With most tomtom's usually removeing the SD card and powering up will resolve the issue.
If not then a HARD reset without the SD card may be called for.
If it does prove to be an SD card error then formatting in a proper card reader using FAT32 as the file system and then copying the files back over from the tomtom usually does the trick.
Or format and restore from a back up to the card. can work too.
It may also mean that a files might have been deleted or become corrupted.
Ok check and see if your gps has memory card in a slot on the gps (about an inch long and maybe 1/8" wide)
If it has then push the card into the gps and let go
it should come out a little to allow you to remove it.
(do that with the power off !)
power up the gps again and if it works the card is a minor fault that can usualyy be fixed by you pretty easily.
If it still does not come on properly then look for a tiny hole near the SD slot
Get a paper clip and and with the gps switched on pust it into that hole keeping the paper clip straight (dont push too hard)
Hold it for about 3 seconds and release.
your gps should reset itself.
If it stays off try to power it up.
It should now power up but you may have to tell it all your personal settings again.
The tomtoms don't die too often compared to other makes
and even when they lock up they can usually be brought back to life
Aug 02, 2008 | Tomtom ONE GPS Receiver
Gps module not responding
can not be fixed from home. i'll have to send it back to lowrance. tried soft reset and hard reset, gps module not responding icon still pops up on screen, thank you for the suggestions.
Jul 11, 2008 | Lowrance GlobalMap 3500C GPS Receiver
Touch screen failed after I added external antenna
have you tried resetting it (press and hold find, the press power)
Dec 04, 2007 | Garmin StreetPilot 2720 GPS Receiver
Fatal Error Message
I have an older one of these with the AV connections. once in a while it does not see GPS signals. If I exit navigation and from the main menu select setup, I can reset the GPS and then go back into navigation, this seems to cure the issue but it may return. I think the root cause is a low memory battery in the unit.
Nov 08, 2007 | Fine Digital FineDrive 400 GPS Receiver
Navigon 2100 Portable GPS Receiver Logo
163 people viewed this question
Top Navigon GPS Experts
perdue40
Are you a Navigon GPS Expert? Answer questions, earn points and help others
