Question about Primera Technology Bravo SE Printer
It says you must select robot and its recorder to write discs
I have used it before, mac os 10.4 and primera bravo. It shows the drive, but is giving me an error, when it says you must select robot and its recorder to write discs it won't let me select anything
    Problem Solver:
  • 15 Answers
Did you install the software? If I remember rightly the Mac version requires Discribe software. Let me know and we'll see if we can narrow it down.
Posted on Aug 25, 2009
My laptop does not recognize my iomega hard drive
You need to format your drive to work with your Mac. The drive is shipped formatted as NTFS (Windows).
I'm going to assume that you are using Mac OS X 10.5 or later.
1. Open Disk Utility
2. Select Applications > Utilities > Disk Utility
3. In the left hand column, click on the drive icon for the Iomega Hard Drive.
********Make sure you click on the high level icon, not the second level volume icon.********
4. Select the Partition tab.
5. Change Volume Scheme from Current to 1 Partition.
6. Select the format type from the Format drop-down menu.
Select Mac OS Extended (Journaled) (recommended) or Mac OS Extended.
7. Click on the Options button.
8. Select the type of partition you want to use:
GUID Partition Table - for boot ability on Intel-based Macs
Apple Partition Map - for boot ability on PowerPC-based Macs
Master Boot Record - if you will use the drive on a PC as well as your Mac. Use this option ONLY if you selected PC-DOS as the format type.
CAUTION! In most cases, the computer will fail to format the drive as a Mac OS Extended (HFS+) partition using Master Boot Record. For best results, always choose GUID Partition Table (Intel) or Apple Partition Map (PowerPC).
9. Click OK.
10. Click Apply (10.5-10.6) or Partition (10.4). The drive is ready to use when the format completes.
Dec 17, 2010 | Iomega Prestige 500 GB USB 20 Hard Drive
Similar pick up and drop problem
Try reinstalling the drivers. Does the printer tray retract?
Jul 13, 2009 | Primera Technology Primera BravoPro...
BRAVO PRIMERA 11 ERROR CD PUBLISHER
The Publisher has a cartridge problem. Check to make certain that the cartridges are installed correctly and that the bar code labels on the underside of the cartridge are not damaged.
Jul 13, 2009 | Primera Technology Bravo 2 Disc...
Primera Bravo Pro grabs 2 discs frequently
Hi I use to bye verbatim in 50pcs cackebox then there is no problem... when i bye cheep discs and in 100 or 200 spindels i also some times get problems..
Jun 12, 2009 | Primera Technology Primera BravoPro...
Impossible to burn a DVD on a Bravo Discpublisher II
You cannot burn CD's onto DVD's. The sytems is rejecting the discs as its the wrong media format.
Mar 11, 2009 | Primera Technology Bravo (Refurbished)...
Hiya how do i check the inks on my bravo 2 primera
Go into your printer driver; ie. control panel -> printers and right click the CD/DVD printer. Press "Printing Preferences" near the bottom of the Properties window. Click on "Clean/Change cartrdiges & check Ink" and select properties.
Mar 05, 2009 | Primera Technology Bravo II AutoPrinter...
Can I change the cd drive in a primera composer pro to dvd drive myself? I dont want to pay 300$ to change a 30$ drive if i can do it myself. I saw in another post that if a drive goes bad it can be...
The factory says that you cannot change the drive from a CD drive to a DVD drive yourself. Although you can physically make the change, they indicate that the motherboard needs to be modified or changed in order to switch from CD to DVD. That's why they get $400 to make the upgrade. They don't provide any parts to do this, either, because I'm sure it wouldn't be a trivial change.
Dec 28, 2008 | Primera Technology Bravo II DVD Duplicator...
Primera Bravo Pro
Pioneer 115's require a special firmware to allow the drive trays to eject far enough so that the robot can drop the discs into the tray cleanly. The firmware for the 115 can be found at http://www.primera.com/downloads/support/DriveFirmware/DriveFirmware.html. Hopefully this should fix your problem.
Aug 04, 2008 | Primera Technology Primera BravoPro...
Bravo II disk pickup problem
Chances are your burner is probably going/gone bad. Simply open the system carefully and replace the drive. Worked for me! hope this helps.
May 02, 2008 | Primera Technology Bravo II DVD Duplicator...
Primera Bravo II
Thanks..piece of cake. A few things to know.
1. The entire robot mechanism does not have to be taken apart, but it has to be taken out in order to get to the screws that hold the drive.
2. Make sure you use the correct holes when installing the drive. If not the robot will not be in the center of the disk when it goes to pick it up.
3. I did it in less than an hour. Drive cost me 22 bucks.
Feb 26, 2008 | Primera Technology Bravo II DVD Duplicator...
Primera Technology Bravo SE Printer Logo
129 people viewed this question
Top Primera Technology Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Primera Technology Office Equipment and Supply Expert? Answer questions, earn points and help others
