Question about Frigidaire GLTF2940F Front Load Washer
Washer does not spin at the end of the cycle.
    Scholar:
  • 61 Answers
Check that you do not have the crease gaurd or rinse hold button depressed? does it spin at all can you put it on a spin cycle with clothes in and no clothes in?
Posted on Jul 23, 2009
Illeagle
  • 525 Answers
SOURCE: Maytag LAT9706AAM Washer - Spin Cycle problems
If the timer is advancing but won't spin out, it is possible that the spin contacts inside the timer are faulty. A technician will normally isolate and confirm this diagnosis witth a special power cord hookup to the motor. From the way you describe your complaint, I feel that a timer would correct your problem.
Hope this advice is helpful!
Posted on May 27, 2008
  • 10 Answers
SOURCE: Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
Posted on Dec 15, 2007
SOURCE: GE WCVH6260 Front Load Washer
thank you ...thank you...thank you. i never knew that there was a filter..as ge manuel says nothing about that. got 2.75 in change, a few rusted screws and assorted other **** out of it. runs like new
Posted on Nov 27, 2008
  • 54 Answers
SOURCE: whirlpool washer LSQ9549LW1- loud thunks at end of spin cycle
you can goto sears.com and goto parts, put in your model # and they have a parts and diagram that you can look at.. sound like your basket block (which holds your basket on the gear shaft) is loose.. or 3 bolts on bottom of washer the holds gearbox to frame is loose.. good luck
Posted on Jan 21, 2009
  • 12 Answers
SOURCE: Kenmore model 110 washer will not drain at end of wash cycle
It could be the lid switch or the timer.
Posted on Jan 31, 2009
Maytag Centennial washer makes loud bang and the end of cycle.
I don't think it would be the bearing, as no sounds abnormal occur during it's wash cycle. I think it's at the end of the spin dry cycle, that a "brake" is applied which stops the drum from spin drying, but is being applied overly hard, which causes the drum to "BANG", stop abruptly by the brake. Only a washer repairman could deal with that problem, but, it's NOT dangerous to the washer, IF that's what the problem is. Contact a washer repairman in your area, and they'll probably be able to tell you if it's THAT or something more serious, which I doubt. The reason why the washer moves a bit when at the end of the cycle is probably because the brake which causes the spin dry cycle to come to it's end, does so very fast, which displaces the centrifugal energy abruptly towards lateral motion. Not really dangerous either.
Sep 19, 2012 | Maytag Parts Washing Machines
Washer squeals at end of spin cycle
The manufacturer recommends you tilt back the washer and spray some penetrating oil into and around the brake package to stop the squeal.
Jan 18, 2010 | Maytag Atlantis MAV6451 Top Load Washer
During spin cycle washer spins fine but toward the end of the cycle it spins out of control like it is out of balance? Any help is greatly welcomed.
Some front loaders have a super high speed at the end of the spin. Front loaders don't like small loads, the laundry does not spread out evenly enough for a balanced spin.
May 08, 2009 | Frigidaire ATF6000ES Front Load Washer
Spins so harder washer walks across the room. the washer is level. the load is balanced. is it the tub inside the washer that is not level
Engage your lid switch so that washer will spin in spin cycle and watch it spin. At end of cycle when washer shuts down the tub should come to a fairly sudden stop if it doesn't then you need to have the brake worked on. If it does post your model number and i'll advise further.
Mar 11, 2009 | Roper RAS8445KQ Top Load Washer
Whirlpool Duet stuck on spin cycle
Press 'end of cycle' for over 3 seconds. Perhaps you have to check your filter, maybe clogged.
Feb 28, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Will not spin dry at the end of the wash cycle
Check the brushes in the motor. This is a normal problem.
Jan 22, 2008 | Zanussi W1242W Front Load Washer
98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Washer makes loud thumping after finished spin cycle
I replaced the drive block and it solved my problem. (thumping noise at the end of spin cycle) Easy repair. Videos on utube show all the steps.
Jun 07, 2006 | Whirlpool LSR7333 Top Load Washer
Frigidaire GLTF2940F Front Load Washer Logo
321 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
